Extended cycle <EXTCYCLE>
Use the extended cycle command <EXTCYCLE> to process standard cycles. The following is the list of standard cycles supported by the <EXTCYCLE> command:
Command:
EXTCYCLE ON(71) | CALL(52) | OFF(72)
LATHEFINISH(400) | LATHEROUGH(401) | LATHEGROOVE(402) |
LATHETHREAD(403) | DRILL(163) | FACE(81) | TAP(168) |
BRKCHP(288) | DEEP(153) | W5DDrill(481) | W5DFace(482) |
W5DChipRemoving(483) | W5DChipBreaking(473) | W5DTap(484) |
W5DBore5(485) | W5DBore6(486) | W5DBore7(487) | W5DBore8(488) |
W5DBore9(489) | W5DThreadMill(490) | W5DHolePocketing(491)
{, a} {, b} {, c} {, d} ...
Parameters:
Parameter
CLD array
Description
ON(71),
CALL(52),
OFF(72)
CLD[1]
CLD.SubCmd
Command modifier:
ON(71) – turn standard cycle ON,
CALL(52) – call standard cycle,
OFF(72) – turn standard cycle OFF.
LATHEFINISH(400),
LATHEROUGH(401),
LATHEGROOVE(402),
LATHETHREAD(403),
DRILL(163),
FACE(81),
TAP(168),
BRKCHP(288),
DEEP(153),
W5DDrill(481),
W5DFace(482),
W5DChipRemoving(483),
W5DChipBreaking(473),
W5DTap(484),
W5DBore5(485),
W5DBore6(486),
W5DBore7(487),
W5DBore8(488),
W5DBore9(489),
W5DThreadMill(490),
W5DHolePocketing(491),
WProbing(500)
CLD[2]
CLD.SubType
Cycle type identifier.
a, b, c, d …
CLD[3] – CLD[258]
CLD.CLParams(1) – CLD.CLParams(256)
Cycle parameters list.
The first parameter is used to specify the start, call and cancellation of the standard cycle.
SprutCAM system usually generates technology command sequence containing <EXTCYCLE> command similar to the following:
EXTCYCLE ON(71) ...
FEDRAT ...
GOTO ...
GOTO ...
EXTCYCLE CALL(52) ...
FEDRAT ...
GOTO ...
GOTO ...
FEDRAT ...
GOTO ...
GOTO ...
EXTCYCLE OFF(72) ...
The list of parameters depends on the cycle type.
