EDM Movement <EDMMOVE>
EMD movement command is generated by the Wire EDM operations of the SprutCAM system. The command specifies the wire movement coordinates and sets the movement interpolation modes.
Command:
EDMMOVE MODE: RAPID(0) | 2AXIS(1) | TAPER(2) | MULTIPROF(3)| 4AXIS(4),
SPAN1: CUT(0) | ARC(1), SPAN2: CUT(0) | ARC(1),
EP1: (X x; Y y; Z z), EP2: (X x; Y y; Z z),
PC1: (X x; Y y), PC2: (X x; Y y), R1 r1, R2 r2, A a,
ROLLMODE: OFF(0) | SHARP(1) | CONICAL(2) | CYLINDRICAL(3) |
FIXED(4),
ROLLR1 rollr1, ROLLR2 rollr2
Parameters:
Parameter
CLD array
Description
Movement mode
CLD[1]
CLD.Mode
RAPID(0) – Rapid movement,
2AXIS(1) – 2 axis movement,
TAPER(2) – 2 axis movement with taper,
MULTIPROF(3) – multiprofile movement (arcs and lines),
4AXIS(4) – 4 axis movement (lines only)
Lower contour element type
CLD[2]
CLD.Span1
CUT(0) – a line,
ARC(1) – an arc
Upper contour element type
CLD[3]
CLD.Span2
CUT(0) – a line,
ARC(1) – an arc
Lower contour element endpoint, EP1
CLD[4],
CLD[5],
CLD[6]
CLD.Ep1X,
CLD.Ep1Y,
CLD.Ep1Z
X, Y and Z coordinates of the lower contour element endpoint
Upper contour element endpoint, EP2
CLD[7],
CLD[8],
CLD[9]
CLD.Ep2X,
CLD.Ep2Y,
CLD.Ep2Z
X, Y and Z coordinates of the upper contour element endpoint
Lower contour arc center point, PC1
CLD[10],
CLD[11]
CLD.Pc1X,
CLD.Pc1Y
X и Y coordinates of the lower contour arc center point, if this element is an arc.
Upper contour arc center point, PC2
CLD[12],
CLD[13]
CLD.Pc2X,
CLD.Pc2Y
Lower contour arc radius, R1
CLD[14]
CLD.R1
If the lower contour element is an arc, then the parameter specifies the signed arc radius:
R > 0 – the arc is counterclockwise,
R < 0 – the arc is clockwise.
Upper contour arc radius, R2
CLD[15]
CLD.R2
If the upper contour element is an arc, then the parameter specifies the signed arc radius:
Taper angle, A
CLD[16]
CLD.A
In the TAPER(2) movement mode the parameter specifies signed taper angle:
A > 0 – right taper,
A < 0 – left taper.
Sharp angle rolling mode, ROLLMODE
CLD[17]
CLD.RollMode
This parameter specifies sharp angle roll mode for the 2 axis and taper machining (CornerR function):
OFF(0) – the corner rolling is off (R1 = 0, R2 = 0);
SHARP(1) – in this mode only the lower contour angles are rolled (R1 = R1, R2 = 0);
CONICAL(2) – both lower and upper contour angles are rolled, rounding radiuses are derived from taper angle (R1 = R1, R2 = R1 + <Taper offset>);
CYLINDRICAL(3) – lower and upper contour angles are rounded, rounding radiuses are equal (R1 = R1, R2 = R1);
FIXED(4) – lower and upper contour angles are rounded, rounding radiuses are independent (R1 = R1, R2 = R2)
Lower contour element roll radius, ROLLR1
CLD[18]
CLD.RollR1
This parameter specifies the rolling radius of the sharp angle of the lower contour element
Upper contour element roll radius, ROLLR2
CLD[19]
CLD.RollR2
This parameter specifies the rolling radius of the sharp angle of the upper contour element
