Lathe drilling cycle G82 <FACE>
Lathe drilling canned cycle <FACE(81)> G82 drills axial holes with static tool inside rotated workpiece. The tool approaches the hole at the safe plane level descends at rapid feedrate to the return level, machines the hole at work feedrate, dwells at the hole bottom, and rapidly retracts to the safe plane level.
images/download/attachments/95446633/820860ab-6abf-4780-9d05-be350641b326.bmp
Parameters:
CLD array
Description
CLD[1]
CLD.SubCmd
Command type:
ON(71) – canned cycle on,
CALL(52) – canned cycle call,
OFF(72) – canned cycle off.
CLD[2]
CLD.SubType
Canned cycle type identifier: FACE(81).
CLD[3]
CLD.CLParams(1)
The top level of a hole (T).
CLD[4]
CLD.CLParams(2)
The hole depth measured relative to the top level (D).
CLD[5]
CLD.CLParams(3)
The return level (R).
CLD[6]
CLD.CLParams(4)
The Safe level (S).
CLD[7]
CLD.CLParams(5)
Dwell at hole bottom level (seconds).
CLD[8]
CLD.CLParams(6)
The federate units:
0 – mm/rev,
1 – mm/min.
CLD[9]
CLD.CLParams(7)
The Work feed.
CLD[10]
CLD.CLParams(8)
The Retract feed.
Extended cycle <EXTCYCLE>
