Drilling cycle G88 <W5DBore8>
Drilling cycle type <W5DBore8(488)> (G88) drills holes with rapid approach to the safe level, dwell at hole bottom level, spindle stop and manual retract to the safe plane level.
images/download/attachments/95446685/G88.PNG
Drilling cycle G88 consist of the following steps:
  • Rapid tool motion to the hole center at the <Z return> level.
  • Rapid descend to the <Z safe> level.
  • Work feedrate motion to the <Z min> level.
  • <Dwell> at the <Z min> level.
  • <Spindle stop>.
  • Manual tool retract to the <Z return> level.
  • Restore the spindle rotation direction and speed.
Parameters:
CLD array
Description
CLD[1]
CLD.SubCmd
Command type:
ON(71) – canned cycle on,
CALL(52) – canned cycle call,
OFF(72) – canned cycle off.
CLD[2]
CLD.SubType
Canned cycle type identifier: W5DBore8(488) (G88).
CLD[3]
CLD.CLParams(1)
Nx, X coordinate of the tool normal vector
CLD[4]
CLD.CLParams(2)
Ny, Y coordinate of the tool normal vector
CLD[5]
CLD.CLParams(3)
Nz, Z coordinate of the tool normal vector
CLD[6]
CLD.CLParams(4)
Sf, Normal distance from current tool position to the safe plane level
CLD[7]
CLD.CLParams(5)
Tp, Normal distance from current tool position to the hole top level
CLD[8]
CLD.CLParams(6)
Bt, Normal distance from current tool position to the hole bottom level
CLD[9]
CLD.CLParams(7)
Work feed measurements: 0 – mm/rev,
1 – mm/min
CLD[10]
CLD.CLParams(8)
Work feed value
CLD[11]
CLD.CLParams(9)
Approach feed measurements: 0 – mm/rev,
1 – mm/min
CLD[12]
CLD.CLParams(10)
Approach feed value
CLD[13]
CLD.CLParams(11)
Return feed measurements: 0 – mm/rev,
1 – mm/min
CLD[14]
CLD.CLParams(12)
Return feed value
CLD[15]
CLD.CLParams(13)
Delay at the bottom level in seconds
CLD[50]
CLD.CLParams(48)
What spindle is used to machining:
1 - driven tool,
2 - workpiece spindle (lathe).
images/download/attachments/95446685/828e7fc8-cde3-48bb-af20-025c6f95c6c5.bmp
Extended cycle <EXTCYCLE>
