Lathe grooving cycle G74, G75 <LATHEGROOVE>
Cycle <LATHEGROOVE(402)> implements the G74 cylindrical grooving canned cycle and G75 face grooving canned cycle. Groove shape is rectangular and is defined by its dimensions: width and height. The cutting is done by consequent work passes of the tool with Z and X axes stepping.
images/download/attachments/95446607/f_clip0030.bmp
Parameters:
CLD array
Description
CLD[1]
CLD.SubCmd
Command type:
ON(71) – canned cycle on,
CALL(52) – canned cycle call,
OFF(72) – canned cycle off.
CLD[2]
CLD.SubType
Canned cycle type identifier: LATHEGROOVE(402)
CLD[3]
CLD.CLParams(1)
The groove type:
0 – turn groove (G75),
1 – face groove (G74)
CLD[4]
CLD.CLParams(2)
The signed width of the groove measured relative to the start point (W)
CLD[5]
CLD.CLParams(3)
The signed height of the groove measured relative to the start point (H)
CLD[6]
CLD.CLParams(4)
The absolute amount of the machining step by width (D)
CLD[7]
CLD.CLParams(5)
The absolute value of the machining step by height (chip breaking depth, L)
CLD[8]
CLD.CLParams(6)
The absolute distance of the side retract before return of tool (R)
CLD[9]
CLD.CLParams(7)
The absolute value of the lead out for chip breaking.
CLD[10]
CLD.CLParams(8)
Delay at the bottom in seconds
CLD[11]
CLD.CLParams(9)
Chip breaking mode:
  • 0 - do not use,
  • 1 - on first plunge,
  • 2 - on every plunge.
CLD[12]
CLD.CLParams(10)
Width rough stock
CLD[13]
CLD.CLParams(11)
Height rough stock
If a "signed" parameter is positive it is laid off in the positive direction of respective axis, otherwise it is laid off in negative direction.
Extended cycle <EXTCYCLE>
