Tapping cycle G84 <W5DTap>
Tapping cycle <W5DTap(484)> (G84) performs rapid approach to the <Z return> level, thread tapping with subsequent retraction at work feedrate with reverse spindle rotation.
images/download/attachments/95446665/G84.PNG
G84 tapping cycle includes:
  • Rapid approach to the hole center at the <Z return> level.
  • Rapid travel to the <Z safe level>.
  • Work feedrate motion the <Z min> level.
  • Spindle reverse rotation and work feedrate trave to <Z safe> level.
  • Rapid retract to the <Z return> level.
  • Restore spindle rotation direction and speed.
If the appropriate setting is enabled, then tap retracts to break / remove chip during the cycle execution. Way to break chips is determined by CLD [20] parameter.
CNC-systems often have different tapping canned cycles for fixed and floating socket types. Socket type is specified by the <CLD[19]> (CLD.CLParams(17)) parameter.
Parameters:
CLD array
Description
CLD[1]
CLD.SubCmd
Command type:
ON(71) – canned cycle on,
CALL(52) – canned cycle call,
OFF(72) – canned cycle off.
CLD[2]
CLD.SubType
Canned cycle type identifier: W5DTap(484).
CLD[3]
CLD.CLParams(1)
Nx, X coordinate of the tool normal vector
CLD[4]
CLD.CLParams(2)
Ny, Y coordinate of the tool normal vector
CLD[5]
CLD.CLParams(3)
Nz, Z coordinate of the tool normal vector
CLD[6]
CLD.CLParams(4)
Sf, Normal distance from current tool position to the safe plane level
CLD[7]
CLD.CLParams(5)
Tp, Normal distance from current tool position to the hole top level
CLD[8]
CLD.CLParams(6)
Bt, Normal distance from current tool position to the hole bottom level
CLD[9]
CLD.CLParams(7)
Work feed measurements: 0 – mm/rev,
1 – mm/min
CLD[10]
CLD.CLParams(8)
Work feed value
CLD[11]
CLD.CLParams(9)
Approach feed measurements: 0 – mm/rev,
1 – mm/min
CLD[12]
CLD.CLParams(10)
Approach feed value
CLD[13]
CLD.CLParams(11)
Return feed measurements: 0 – mm/rev,
1 – mm/min
CLD[14]
CLD.CLParams(12)
Return feed value
CLD[15]
CLD.CLParams(13)
Delay at the bottom level in seconds
CLD[16]
CLD.CLParams(14)
Delay at the top level in seconds
CLD[17]
CLD.CLParams(15)
Thread step
CLD[18]
CLD.CLParams(16)
Initial spindle angle in degrees (for multistart threads)
CLD[19]
CLD.CLParams(17)
Tap socket type:
0 – floating (compensative),
1 – fixed (uncompensative)
CLD[20]
CLD.CLParams(18)
The way to break chip :
0 – without chip breaking,
1 – chip removing,
2 – chip breaking
CLD[21]
CLD.CLParams(19)
St, chip breaking step value
CLD[22]
CLD.CLParams(20)
Dg, each iteration chip breaking step degression
CLD[23]
CLD.CLParams(21)
Dc, before drilling deceleration value for each step
CLD[24]
CLD.CLParams(22)
Ld, each step lead out value for cutting process breaking
CLD[50]
CLD.CLParams(48)
What spindle is used to machining:
1 - driven tool,
2 - workpiece spindle (lathe).
images/download/attachments/95446665/W5DSchema.png
Extended cycle <EXTCYCLE>
