Drilling with chip removing cycle G83 <W5DChipRemoving>
Drilling with chip removing cycle <W5DChipRemoving(483)> (G83) performs tool motion to the hole center at the <Z return> level and consequent cyclic drill with tool retraction to the <Z safe> level.
Cycle consists of:
Rapid approach to the hole center at the <Z return> level.
Rapid travel to the <Z safe> level.
Work feedrate motion to the <Step depth S>.
<Dwell> for the <Delay at the bottom> time.
Rapid return to <Z safe> level.
<Dwell> for the <Dwell at the top> time.
Rapid motion to the previous depth level, with a <Deceleration (Dcl)>.
Work feedrate to the <Deceleration (Dcl)> with <Step (S)>.
<Dwell> at for the <Dwell at the bottom> time.
Repeat previous five iterations until the full hole depth is reached.
Rapid tool return to the <Z retract> level.
Parameters:
     Description  |
     CLD[1]  |
     CLD.SubCmd  |
     Command type: ON(71) – canned cycle on, CALL(52) – canned cycle call, OFF(72) – canned cycle off.  |
     CLD[2]  |
     CLD.SubType  |
     Canned cycle type identifier: W5DChipRemoving(483).  |
     CLD[3]  |
     CLD.CLParams(1)  |
     Nx, X coordinate of the tool normal vector  |
     CLD[4]  |
     CLD.CLParams(2)  |
     Ny, Y coordinate of the tool normal vector  |
     CLD[5]  |
     CLD.CLParams(3)  |
     Nz, Z coordinate of the tool normal vector  |
     CLD[6]  |
     CLD.CLParams(4)  |
     Sf, Normal distance from current tool position to the safe plane level  |
     CLD[7]  |
     CLD.CLParams(5)  |
     Tp, Normal distance from current tool position to the hole top level  |
     CLD[8]  |
     CLD.CLParams(6)  |
     Bt, Normal distance from current tool position to the hole bottom level  |
     CLD[9]  |
     CLD.CLParams(7)  |
     Work feed measurements: 0 – mm/rev, 1 – mm/min  |
     CLD[10]  |
     CLD.CLParams(8)  |
     Work feed value  |
     CLD[11]  |
     CLD.CLParams(9)  |
     Approach feed measurements: 0 – mm/rev, 1 – mm/min  |
     CLD[12]  |
     CLD.CLParams(10)  |
     Approach feed value  |
     CLD[13]  |
     CLD.CLParams(11)  |
     Return feed measurements: 0 – mm/rev, 1 – mm/min  |
     CLD[14]  |
     CLD.CLParams(12)  |
     Return feed value  |
     CLD[15]  |
     CLD.CLParams(13)  |
     Delay at the bottom level in seconds  |
     CLD[16]  |
     CLD.CLParams(14)  |
     Delay at the top level in seconds  |
     CLD[17]  |
     CLD.CLParams(15)  |
     St, chip removing step value  |
     CLD[18]  |
     CLD.CLParams(16)  |
     Dg, each iteration chip removing step degression  |
     CLD[19]  |
     CLD.CLParams(17)  |
     Dc, before drilling deceleration value for each step  |
     CLD[50]  |
     CLD.CLParams(48)  |
     What spindle is used to machining: 1 - driven tool, 2 - workpiece spindle (lathe).  |
