The list of CLData technology commands:
N
Command
Code
Description
AXESBRAKE
2012
Machine axes brakes control
2
CIRCLE
15000
Circle movement
3
COMMENT
1065
Commentaries
4
COOLNT
1030
Cooling
5
CUTCOM
1007
Tool compensation
CYCLE
1054
Hole machining canned cycles
7
DELAY
1010
Delay
8
EDMMOVE
16001
EDM movement
9
EXTCYCLE
1053
Extended cycle
10
FEDRAT
1009
Feedrate
11
FINI
14000
Ending record
12
FROM
5003
Original point
13
GOHOME
17
Return to original position
14
GOTO.abs
5005
Linear transition
15
HEAD
1002
Spindle head number
16
INSERT
1046
Insertion
17
INTERPOLATION
1047
Interpolation mode
18
LOADTL
1055
Tool loading
19
MULTIARC
9014
Multiaxis circle movement
20
MULTIGOTO
9010
Multi coordinate movement
21
OPSKIP
1012
Optional skipping
22
OPSTOP
2003
Auxiliary stop
23
ORIGIN
1027
Original coordinates
24
PALETA
1001
Palette changing
25
PARTNO
1045
Part number
26
PhysicGOTO
9013
Physical machine axes movement
27
PLANE
99
Working plane
28
PPFUN
1079
Postprocessor function
29
PPRINT
1044
Postprocessor printing
30
RAPID
2005
Rapid feedrate
31
ROTABL
1026
Table rotation
32
SAFPOS
1094
Tool change point
33
SELWORKPIECE
2011
Active workpiece holder selection
34
SINGLETHREAD
1037
Singlethread command
35
SPINDL
1031
Spindle
36
STOP
2002
Stop
37
STRUCTURE
2015
Structure command
38
TAKEOVER
2010
Workpiece takeover
39
TLCONTACT
2017
Tool contact command
40
WAIT
2014
Waiting for synchronization point
Additional words:
N
Word
Code
Description
BOTH
83
Both
2
BRKCHP
288
Chip breaking
3
CCLW
59
Counter clockwise
4
CLW
60
Clockwise
5
CUTS
511
Cuts
DEEP
153
Deep drilling
7
DEPTH
510
Depth
8
DRILL
163
Drill
9
DWELL
279
Dwell
10
FACE
81
G82 canned cycle
11
FINCUT
512
Final cut
12
INCR
66
Increment
13
LENGTH
9
Length
14
MMPM
315
Millimeters per minute
15
MMPR
316
Millimeters per revolution
16
MULTRD
119
Multi-start thread
17
OFF
72
Turn off
18
ON
71
Turn on
19
ORIENT
246
Orientation
20
TAP
168
Tapping
21
XYPLAN
33
XY plane
22
YZPLAN
37
YZ plane
23
ZXPLAN
41
ZX plane
24
R
23
Radius
25
RGT
24
Right tool positioning
26
LEFT
8
Left tool positioning
