Tool compensation <CUTCOM>
Use <CUTCOM> command to switch compensation mode for length or radius of the tool.
Command:
CUTCOM ON(71)|OFF(72), LENGTH(9)|R(23) lr, X x, Y y, Z z,
XY n, YZ m, XZ k, RIGHT(24)|LEFT(8)
Parameters:
Parameter
CLD array
Description
ON(71)
OFF(72)
CLD[1]
CLD.OnOff
Command type:
71 – Enable compensation,
72 – Disable compensation.
LENGTH(9)
R(23)
CLD[2]
CLD.Length
Compensation kind:
9 – tool length compensation,
23 – tool radius compensation.
LR
CLD[3]
LCD.LR
Tool length or radius compensation value.
x,
y,
z
CLD[4],
CLD[5],
CLD[6]
CLD.X
CLD.Y
CLD.Z
Compensation along axes.
n,
m,
k
CLD[7],
CLD[8],
CLD[9]
CLD.N
CLD.M
CLD.K
Plane compensation values.
RIGHT(24)
LEFT(8)
CLD[10]
CLD.RGT
Tool radius compensation direction:
24 – right compensation,
9 – left compensation.
To create ISO postprocessor using masks use ISO.G values which correspond to <CUTCOM> parameters:
CLD parameter
ISO value
CLD[1] = 72,
CLD[2] = 9
ISO.G = 49
CLD[1] = 71,
CLD[2] = 9
ISO.G = 43
CLD[1] = 72,
CLD[2] = 23
ISO.G = 40
CLD[1] = 71,
CLD[2] = 23,
CLD[10] = 24
ISO.G = 42
CLD[1] = 71,
CLD[2] = 23,
CLD[10] = 8
ISO.G = 41
