Workpiece takeover <TAKEOVER>
Use <TAKEOVER> command to take workpiece over from the active holder into the holder specified in the command parameter. The active workpiece holder is specified by the <SELWORKPIECE> command. The workpiece holder is a machine unit that is used to fix the workpiece. Use this command for multi-spindle lathe or lathe-milling machines to perform workpiece takeover from one spindle into another.
Command:
TAKEOVER WorkpieceHolderID
The <TAKEOVER> command's single parameter is the string identifier of the workpiece holder. This identifier is defined by the SprutCAM machine scheme. Parameter value is stored into the <CLDATA$> predefined variable.
Active workpiece holder selection &lt;SELWORKPIECE&gt;
