Feedrate <FEDRAT>
<FEDRAT> defines the value and the type of tool feed. The feed value is stored until the next <FEDRAT> command or <RAPID> command.
SprutCAM uses <FEDRAT> to pass the machining condition code.
Command:
FEDRAT NM nm, K k, MMPM(315) | MMPR(316)
Parameters:
Parameter |
Description |
nm |
CLD[1] |
CLD.NM |
Feed value. |
k |
CLD[2] |
CLD.K |
Feed type (work feed, approach feed, retract feed, transition feed, cut-in feed, etc.).
For EDM operation SprutCAM uses this parameter to pass machining condition code. |
MMPM(315) MMPR(316) |
CLD[3] |
CLD.MMPM |
Feedrate units: MMPM(315) – mm per minute, MMPR(316) – mm per revolution |
