Cooling <COOLNT>
<COOLNT> command turns on or off the machine cooling systems. The first parameter specifies command type: activation or deactivation. The second parameter is the tube number which is affected by the <COOLNT> command.
Command:
COOLNT ON(71)|OFF(72), N n
Parameters:
Parameter |
Description |
ON(71) OFF(72) |
CLD[1] |
CLD.OnOff |
Command type: ON(71) – activate coolant, OFF(72) – deactivate coolant. |
n |
CLD[2] |
CLD.N |
Coolant tube number: 1 – flood, 2 – mist, 3 – tool. |
To create ISO postprocessor using masks use ISO.M values which correspond to parameters:
CLD parameter |
ISO value |
CLD[1] = 71 |
ISO.M = 8 |
CLD[1] = 72 |
ISO.M = 9 |
