Hole machining cycles <CYCLE>
<CYCLE> command is used to pass standard drilling cycles G81-G89. Use <CYCLE> command to determine cycle type and process the cycle accordingly. Cycle type is specified by the first parameter, other parameters types and their number depends on the cycle type.
Command:
CYCLE ON(71) | OFF(72) | DRILL(163) | FACE(81) | DEEP(153) |
BRKCHP(288) | TAP(168) | BORE5(209) | BORE6(210) | BORE7(211) |
BORE8(212) | BORE9(213)
Parameters:
Usually SprutCAM generates drilling technology similiar to the following:
GOTO.abs X, Y, Z ! Position the tool at the first hole.
CYCLE DRILL(163) ! Perform the drilling calling cycle of appropriate type.
GOTO.abs X, Y, Z ! Move the tool to the next hole.
GOTO.abs X, Y, Z ! Move the tool to the last hole.
CYCLE DRILL(163) ! Perform drilling by calling cycle of appropriate type.
CYCLE OFF(72) ! Turn cycle off.
The first drilling cycle command should form the NC-block containing a cycle definition (like G81) and cycle parameters.For example:
G81 X_Y_Z_R_F_
Following commands processing should form block containining only the changed registers. For example:
X_Y_Z_
X_Y_Z_
X_Y_Z_
The <CYCLE OFF(72)> command should form the code of cancelling cycle. For example:
G80
When developing ISO postprocessors using masks ISO.G operator can be used. The value of ISO.G is set automatically according to the following table:
CLD parameter value
ISO.G value
CLD[1] = 163
ISO.G = 81
CLD[1] = 81
ISO.G = 82
CLD[1] = 168
ISO.G = 84
CLD[1] = 209
ISO.G = 85
CLD[1] = 210
ISO.G = 86
CLD[1] = 211
ISO.G = 87
CLD[1] = 212
ISO.G = 88
CLD[1] = 213
ISO.G = 89
CLD[1] = 153
ISO.G = 83
CLD[1] = 288
ISO.G = 73
CLD[1] = 72
ISO.G = 80
G81 drilling cycle &lt;CYCLE DRILL(163)&gt;
G82 drilling cycle &lt;CYCLE FACE(81)&gt;
G84 drilling cycle &lt;CYCLE TAP(168)&gt;
G85 drilling cycle &lt;CYCLE BORE5(209)&gt;
G86 drilling cycle &lt;CYCLE BORE6(210)&gt;
G87 drilling cycle &lt;CYCLE BORE7(211)&gt;
G88 drilling cycle &lt;CYCLE BORE8(212)&gt;
G89 drilling cycle &lt;CYCLE BORE9(213)&gt;
Deep drilling with chip removing &lt;CYCLE DEEP(153)&gt;
Deep drilling with chip breaking &lt;CYCLE BRKCHP(288)&gt;
