Project information in CLData
The information about the SprutCAM project placed inside CLData available through the Project operator.
You can display it on the screen if on the CLData tab select the first item with the name of the project. Properties will be shown in the parameters tree on the right.
The list of possible properties described in tables below. Information about the properties structure, presented as an XML file, is available in the SprutCAM installation folder in a subfolder Supplement\Operations\CLData.xml.
Parts: Array |
Project.Ptr["Parts"] - The list of structures that contain information about the part. The count of items depend on count of parts in the project. |
Part: ComplexType |
Project.Ptr["Parts"].Item[index] - the structure that contain information about one part. |
Workpiece: Array |
Project.Ptr["Parts"].Item[index].Ptr["Workpiece"] - the list of structures that contain information about workpiece items that correspond to the part with defined index. |
Item: TCLDModelItem |
Project.Ptr["Parts"].Item[index].Ptr["Workpiece"].Item[index2] - the structure that contain information about the one workpiece item. The composition of the properties depends on the type of element. All of them are inheritors from complex type TCLDModelItem, so all elements have one common property - the primitive type. See Possible workpiece items table below. |
PrimitiveType: Integer |
Project.Ptr["Parts"].Item[index].Ptr["Workpiece"].Item[index2].Int["PrimitiveType"] - the type of the geometrical primitive: 0 - Unkbown, 1 - Empty workpiece 2 - Faces (reference to the CAD model) 3 - Casting 4 - Box 5 - Turn envelope 6 - Cylinder 7 - Tube 8 - Prism 9 - Polygonal prism |
EmptyWorkpiece: TCLDModelItem |
Element of the workpiece, which says that the processing begins with a void. For example, if we grow a part from scratch by methods of additive processing |
Box: TCLDModelItem |
The workpiece item representing the parallelepiped given by two points. |
Min: ComplexType |
Left bottom corner point of the box. |
X: Double |
X coordinate of the point |
Y: Double |
Y coordinate of the point |
Z: Double |
Z coordinate of the point |
Max: ComplexType |
Right top corner point of the box |
X: Double |
Y: Double |
Z: Double |
RevBody: TCLDModelItem |
The workpiece item representing the turn envelope defined by the axis around which the rotation is performed and a set of geometric primitives that rotate. |
Origin: ComplexType |
Start point of the rotation axis |
X: Double |
Y: Double |
Z: Double |
Axis: ComplexType |
Vector that represents the axis of rotation |
X: Double |
X coordinate of the vector |
Y: Double |
Y coordinate of the vector |
Z: Double |
Z coordinate of the vector |
Cylinder: RevBody |
The workpiece item representing cylinder along defined axis. It is a successor of the RevBody type, therefore it contains all its properties, which are described above. |
HMin: Double |
Start level of the cylinder. This is the distance along the axis, starting from the point of origin. |
HMax: Double |
Finish level of the cylinder. This is the distance along the axis, starting from the point of origin. |
ROut: Double |
Outer radius of the cylinder. |
Tube: Cylinder |
The workpiece item representing tube along defined axis. It is a successor of the Cylinder type, therefore it contains all its properties, which are described above. |
RInn: Double |
Inner radius (hole radius) of the tube. |
Prism: TCLDModelItem |
The workpiece item representing the prism (extrusion item) defined by the axis along which the extrusion is performed and profile to extrude. |
Start point of the extrusion axis |
X: Double |
Y: Double |
Z: Double |
Axis: ComplexType |
Vector that defines the direction of extrusion |
X: Double |
Y: Double |
Z: Double |
HMin: Double |
Start level of the prism. This is the distance along the axis, starting from the point of origin. |
HMax: Double |
Finish level of the prism. This is the distance along the axis, starting from the point of origin. |
PolygonalPrism: Prism |
The workpiece item representing regular polygonal prism along defined axis. It is a successor of the Prism type, therefore it contains all its properties, which are described above. |
RInn: Double |
The radius of the inscribed circle of the polygon |
Angle: Double |
The angle of rotation of the polygon around the axis |
CornerCount: Integer |
The corners count of the polygon |
Faces: TCLDModelItem |
The workpiece item representing the general form body specified by the CAD model reference. |
Box: ComplexType |
The box around CAD-model. Lets you know the overall dimensions. |
Min: ComplexType |
X: Double |
Y: Double |
Z: Double |
Max: ComplexType |
X: Double |
Y: Double |
Z: Double |
Casting: TCLDModelItem |
Box: ComplexType |
The box around CAD-model with stock. Lets you know the overall dimensions. |
Min: ComplexType |
X: Double |
Y: Double |
Z: Double |
Max: ComplexType |
X: Double |
Y: Double |
Z: Double |
Stock: Double |
The value of stock. |
