Spindle <SPINDL>
<SPINDL> command passes spindle control parameters. <SPINDLE> command is used to define spindle rotation frequency or range of frequencies, surface speed, etc.
Command:
SPINDL ON(71)|OFF(72)|ORIENT(246), NO n, K k,
MODE RPM(0)|RANGE(1)|CSS(2) {, SPEED c}
Parameters:
Parameter |
Description |
ON(71)OFF(72) ORIENT(246) |
CLD[1] |
CLD.OnOff |
Command type: ON(71) – spindle rotation on, OFF(72) – spindle rotation off, ORIENT(246) – oriented spindle stop. |
n |
CLD[2] |
CLD.NO |
Rotation frequency, spindle rotation angle or maximum spindle rotation frequency in CSS mode. |
k |
CLD[3] |
CLD.K |
Range of rotation frequencies. |
RPM(0) RANGE(1) CSS(2) |
CLD[4] |
CLD.Mode |
Mode of the rotation frequency definition: RPM(0) – revolutions per minute, RANGE(1) – range of spindle rotation frequencies, CSS(2) – constant surface speed mode. |
c |
CLD[5] |
CLD.CSS |
Constant surface speed value for the CSS mode. |
To create ISO postprocessor using masks use ISO.M values which correspond to <SPINDL> parameters.
CLD parameter |
ISO value |
CLD[1] = 71 |
ISO.M = 3 |
CLD[1] = 72 |
ISO.M = 5 |
