Deep drilling with chip removing <CYCLE DEEP(153)>
Deep drilling with chip removing cycle performs rapid approach to the safe level and repeated drilling according to specified cut-in depth value <ZI> and withdrawal <Zi> values.
Cycle includes:
Rapid travel to the <Z safe> level.
Work feedrate travel to the <Zl>.
Rapid retract to the <Z safe> level.
Rapid travel to the <Zl> - <Zi> level.
Work feedrate travel to the <Zl> + <Zi> level.
Rapid travel to the 2*<Zl> - <Zi> level.
Repeat until the hole depth level is reached.
Rapid retract to the <Safe plane> level.
Command:
CYCLE DEEP(153), A a, MMPM(315), N nm, F f, L l, I i, P p, T t
or
CYCLE DEEP(153), A a, MMPR(316), M nm, F f, L l, I i, P p, T t
Parameters:
Parameter |
Description |
DEEP(153) |
CLD[1] |
CLD.Type |
Cycle type 153 (DEEP). |
a |
CLD[2] |
CLD.A |
Hole depth in current measure units (mm or inches). |
MMPM(315) MMPR(316) |
CLD[3] |
CLD.MMPM |
Feedrate measure units: 315 (MMPM) – mm per minute (inches per minute), 316 (MMPR) – mm per revolution (inches per revolution). |
nm |
CLD[4] |
CLD.NM |
Work feedrate value. |
f |
CLD[5] |
CLD.F |
Safe level. |
L |
CLD[6] |
CLD.L |
Cut in value Zl |
i |
CLD[7] |
CLD.I |
Withdrawal value Zi |
p |
CLD[8] |
CLD.P |
Safe plane level. |
CLD[9], CLD[10] |
Reserved. |
t |
CLD[11] |
CLD.Top |
Hole top level. |
