G85 drilling cycle <CYCLE BORE5(209)>
G85 boring cycle performs rapid approach to the safe level, work feedrate boring will spindle stop at <Z min> level and work feedrate retract to the safe plane level.
Cycle includes:
Rapid approach to <Z safe> level.
Work feedrate travel to <Z min> level.
Spindle stop.
Work feedrate retract to <Safe plane> level.
Restore spindle rotation direction and speed.
Command:
CYCLE BORE5(209), A a, MMPM(315), N nm, F f, P p, T t
or
CYCLE BORE5(209), A a, MMPR(316), M nm, F f, P p, T t
Parameters:
Parameter |
Description |
BORE5(209) |
CLD[1] |
CLD.Type |
Cycle type 209 (BORE5). |
a |
CLD[2] |
CLD.A |
Hole depth in current measure units (mm or inches). |
MMPM(315) MMPR(316) |
CLD[3] |
CLD.MMPM |
Feedrate measure units: 315 (MMPM) – mm per minute (inches per minute), 316 (MMPR) – mm per revolution (inches per revolution). |
nm |
CLD[4] |
CLD.NM |
Work feedrate value. |
f |
CLD[5] |
CLD.F |
Safe level. |
CLD[6], CLD[7] |
Reserved. |
p |
CLD[8] |
CLD.P |
Safe plane level. |
CLD[9], CLD[10] |
Reserved. |
t |
CLD[11] |
CLD.Top |
Hole top level. |
