G81 drilling cycle <CYCLE DRILL(163)>
G81 simple drilling canned cycle performs drilling with rapid approach to the safe level and consequent retraction to the safe plane.
Cycle includes:
Rapid travel to <safe Z> level.
Work feedrate travel to <Z min> level.
Rapid travel to <Safe plane> level.
Command:
CYCLE DRILL(163), A a, MMPM(315), N nm, F f, P p, T t
or
CYCLE DRILL(163), A a, MMPR(316), M nm, F f, P p, T t
Parameters:
Parameter |
Description |
DRILL(163) |
CLD[1] |
CLD.Type |
Cycle type 163 (DRILL). |
a |
CLD[2] |
CLD.A |
Hole depth in current measure units (mm or inches). |
MMPM(163) MMPR(164) |
CLD[3] |
CLD.MMPM |
Feedrate measure units: 315 (MMPM) – mm per minute (inches per minute), 316 (MMPR) – mm per revolution (inches per revolution). |
nm |
CLD[4] |
CLD.NM |
Feedrate. |
f |
CLD[5] |
CLD.F |
Safe level. |
CLD[6], CLD[7] |
Reserved |
p |
CLD[8] |
CLD.P |
Safe plane level. |
CLD[9], CLD[10] |
Reserved |
t |
CLD[11] |
CLD.Top |
Hole top level. |
