G82 drilling cycle <CYCLE FACE(81)>
G82 drilling with dwell canned cycle performs drilling with rapid approach to safe level, dwell at <Z min> level with work feed rate and retracts to the safe plane level at rapid feed rate. Dwell is specified by command parameters.
G82 drilling cycle includes:
Rapid approach to <Z safe> level.
Work feed rate travel to <Z min> level.
<Dwell> at <Z min> level.
Rapid retraction to <Safe plane> level.
Command:
CYCLE FACE(81), A a, MMPM(315), N nm, F f, P p, DWELL(279) h, T t
or
CYCLE FACE(81), A a, MMPR(316), M nm, F f, P p, DWELL(279) h, T t
Parameters:
Parameter |
Description |
FACE(81) |
CLD[1] |
CLD.Type |
Cycle type 81 (FACE). |
a |
CLD[2] |
CLD.A |
Hole depth in current measure units (mm or inches). |
MMPM(315) MMPR(316) |
CLD[3] |
CLD.MMPM |
Feedrate measure units: 315 (MMPM) – mm per minute (inches per minute), 316 (MMPR) – mm per revolution (inches per revolution). |
nm |
CLD[4] |
CLD.NM |
Feedrate value. |
f |
CLD[5] |
CLD.F |
Safe level. |
CLD[6], CLD[7] |
Reserved. |
p |
CLD[8] |
CLD.P |
Safe plane level. |
DWELL |
CLD[9] |
CLD.DWell |
Dwell time keyword. |
h |
CLD[10] |
CLD.H |
Dwell time in seconds. |
t |
CLD[11] |
CLD.Top |
Hole top level. |
