Log interaction with the interpreter
To record the process of NC program text interpreting a separate log is used. It includes the interaction with the interpreter. Log management is performed on the system settings form, < Additional > tab, <Use log interaction with the interpreter> option.
If the logging option is enabled, then for each calculation in the "G-code based simulation" mode, as well as the "G-code based milling operation", a separate file will be generated with the log of the process of interpreting NC program.
The log is intended for development of own interpreters.
