Turning machining cycle
INCT_LatheStockRemovalCycleFormer - SprutCAM X interface that implements the functionality to simplify the formation of the movements of the turning cycle of turning along the given contour. The object that implements this interface is returned by the INCT_CLData.CreateLatheCycleFormer, INCT_GeomCLData.CreateLatheCycleFormer function when it is executed with the lctStockRemoval parameter.
The interface INCT_LatheStockRemovalCycleFormer2 extends the capabilities of the former for turning cycle movements along a given contour. The new properties and methods are described below. The CreateLatheCycleFormer function returns an object that implements this interface (similar to INCT_LatheStockRemovalCycleFormer).
Purpose:
The execution of movements in different types of turning cycles on a given contour, for different racks in general, repeat the same path:
Tool approach to the starting point or the point of the next approach at the accelerated feed.
Approaching the roughing cut level at rapid feed.
Approach to the roughing cut point parallel to the longitudinal axis at the working feed (rough cut).
Return parallel to the contour along the contour, taking into account the finishing stock to the last point of the roughing cut on the working feed (completion of the roughing cut).
Return to the retraction plane in the flow with accelerated movement.
Return to step 1 if the depth of processing is not reached.
Finishing contour operation (approach to the starting point at an accelerated feed, finishing along the contour at a working feed, retraction at an accelerated feed).
Examples of such cycles, Sinumerik: CYCLE95.
Using a former allows you to set the path of the contour, the retraction plane, the machining step, the type and direction of machining, etc., according to the specified parameters, to form the tool path. And also add the features that are necessary for a particular cycle to the path on any formed section, change the type or value of feed, or skip the tool path prepared by the former.
Former use:
We recommend creating a new turning cycle generator for each new cycle in the NC-code frame, except when the cycle operation is repeated in a new frame. Thus, the interface of the old former must be freed when creating a new one or shutting down the interpreter.
To form commands for tool path along a cycle path, the following steps must be performed:
Get the former interface ( INCT_CLData.CreateLatheCycleFormer, INCT_GeomCLData.CreateLatheCycleFormer ).
Set the indexes of the longitudinal and transverse axes along which the movements will be made (Set_AxisIndexes).
Set the cycle parameters (Set_NCProgram, Set_MachiningType, Set_MachiningDirection, Set_Overlap etc.. see the description below).
If changes to the loop path are needed, set a loop event handler (Set_Events).
Generate commands for the tool path along the cycle path (MakeWorkpath).
Method |
Method description |
Set_AxisIndexes |
The method establishes the indices of the longitudinal and transverse axes along which the movements will be made till the formation of the cycle path. Input parameters: Value (TNCLCAxisIndexes) - Transverse (integer) - index of the transverse axis, Longitudinal (integer) - index of the longitudinal axis. No output parameters. |
Get_AxisIndexes |
The function returns the indices of the longitudinal and transverse axes in which the movements will be made till the formation of the cycle path (TNCLCAxisIndexes). No input parameters |
Set_Plane |
The method sets the current plane for the text of the contour of the NC-code. If the plane is not set, then the current plane from INCT_CLData is used. Input parameters: Value (TNCPlaneType) - current plane for the text of the contour of the NC-code . No output parameters. |
Get_Plane |
The function returns current plane for the text of the contour of the NC-code . No input parameters. |
Set_NCProgram |
The method sets the interface that implements the text of the contour of the NC-code in the former. Input parameter: Value (INCT_Program) - an interface that implements the text of the contour of the NC-code. The contour text can be obtained using the INCT_Kernel.GetProgramByLabels method. No output parameters. |
Get_NCProgram |
The function returns an interface that implements the text of the contour of the NC-code (INCT_Program). No input parameters. |
Set_RecalcContourGeometry |
The method sets a sign of the need to perform an interpretation of the contours NC program. Input parameter: Value (logical) - False - do not interpret the NC program of ther contour if it has already been completed, True - to interpret the NC program of ther contour in any case. No output parameters. |
Get_RecalcContourGeometry |
The function returns the sign of the need to perform the interpretation of the contours NC program. No input parameters. |
Set_MachiningProcessing |
The method sets the machining processing. Input parameter: Value (TNCMachiningProcessing) - machining processing. mpRoughing - roughing (several passes performed taking predetermined parameters: stock, step, etc.).; No output parameters. |
Get_MachiningProcessing |
The function returns the machining processing. No input parameters. |
Set_MachiningType |
The method sets the machining type. Input parameter: Value ( TNCLatheMachinigType ) - machining type. mtInside - inside; No output parameters. |
Get_MachiningType |
The function returns the type of machining (TNCLatheMachinigType). No input parameters. |
Set_MachiningDirection |
The method sets the value of the machining direction. Input parameter: Value (TNCLatheMachiningDirection) - machining direction value. mdLongitudinal - longitudinal; No output parameters. |
Get_MachiningDirection |
The function returns the value of the machining direction (TNCLatheMachiningDirection). No input parameters. |
Set_MachiningStyle |
The method sets the style of the contour when roughing. Input parameters: Value (TNCLatheMachiningStyle) - the style of the contour when roughing. msBars - at each iteration processing paraxial (longitudinal or transverse depending on MachiingDirection); msCopyContour - at each iteration parallel processing contour (repeat countour). No output parameters. |
Get_MachiningStyle |
The function returns the style of the contour when roughing. No input parameters. |
Set_Overlap |
The method sets the overlap type. Input parameter: Value (boolean) - overlap type value. True - with a return along the contour, False - with a direct return. No output parameters. |
Get_Overlap |
The function returns an overlap type (number). No input parameters. |
Set_AxialStock |
The method sets the value of the axial stock for the contour. Input parameter: Value (number) - the value of the axial stock on the contour. No output parameters. |
Get_AxialStock |
The function returns the value of the axial stock for the contour (number). No input parameters. |
Set_RadialStock |
The method sets the value of the radial stock for the contour. Input parameter: Value (number) - the radial stock value of the contour. No output parameters. |
Get_RadialStock |
The function returns the value of the radial stock for the contour (number). No input parameters. |
Set_ProfileStock |
The method sets the value of equidistant stock on the contour. Input parameter: Value (number) - the value of equidistant stock on the contour. No output parameters. |
Get_ProfileStock |
The function returns the value of equidistant stock for the contour (number). No input parameters. |
Set_StartPointMode |
Method sets setting mode 'Starting point of the contour'. Input parameters: Value (TNCLatheStartPointMode) - setting mode 'Starting point of the contour'. spmCalcPoint - cycle is calculated starting point; spmSetPoint - start point is set manually (см. StartPoint). No output parameters. |
Get_StartPointMode |
The function returns the setting mode 'Starting point of the contour'. No input parameters. |
Set_StartPoint |
The method sets a starting point of the cycle (for mode StartPointMode = spmSetPoint). Input parameters: Value (TNC2DPoint) - starting point of the cycle. No output parameters. |
Get_StartPoint |
The function returns the starting point of the cycle. No input parameters. |
Set_EachReliefcutSeparately |
The method sets the value of feature relief cuts processing. Input parameter: Value (logical) - True - each relief cut handled separately, False - all relief cuts are processed in a single pass. No output parameters. |
Get_EachReliefcutSeparately |
The function returns the value of feature relief cuts processing. No input parameters. |
Set_DoReliefcutsInReverseOrder |
This method sets a flag for the order in which reliefcuts are processed. Input parameters: Value (boolean) - a flag for the order in which relief cuts are processed. True - process reliefcuts in the reverse order. False - process relief cuts in the direct order. No output parameters. |
The function returns a flag for the order in which relief cuts are processed . No input parameters. |
Set_StepType |
The method sets the type of calculation of the roughing machining . Input parameter: Value (TNCLatheStepType) - type of calculation roughing machining. stConst - with each pass, the depth of processing is the value of the machining step (Set_Step); No output parameters. |
Get_StepType |
The function returns the type of calculation of the roughing machining . (TNCLatheStepType). No input parameters. |
Set_Step |
The method sets the value of the machining step. Input parameter: Value (number) - machining step value. No output parameters. |
Get_Step |
The function returns the value of the machining step (number). No input parameters. |
Set_SafeDist |
The method sets the retraction value for the return (the value of the rebound to the side before outputting the tool). Input parameter: Value (number) - the value of the outlet. No output parameters. |
Get_SafeDist |
The function returns the value of the retract (number). No input parameters. |
Set_LengthChipBreaking |
The method sets the stroke length for chip breaking. Input parameter: Value (number) - the value of the stroke length for chip breaking. No output parameters. |
Get_LengthChipBreaking |
The function returns the stroke length for chip breaking (number). No input parameters. |
Set_Feedrate |
The method sets the value of the work feed. Input parameter: Value (number) - value of the work feed. No output parameters. |
Get_Feedrate |
The function returns the value of the work feed. No input parameters. |
Set_MPM |
The method sets the type of working feed. Input parameter: Value (logical) - type of working feed. True - mm/min, False - rev/min. No output parameters. |
Get_MPM |
The function returns the type of working feed. No input parameters. |
Set_UseContourFeedrate |
The method sets the flag 'Use feed specified in the NC-code of the contour'. Input parameters: Value (boolean) - flag 'Use feed specified in the NC-code of the contour'. True - feed specified in the NC-code of the contour, used when processing the same sections of the contour. False - feed specified in the NC-code of the contour is ignored. No output parameters. |
Get_UseContourFeedrate |
The function returns the flag 'Use feed specified in the NC-code of the contour' . No input parameters. |
Set_Events |
The method assigns events to control the behavior of the loop. When using events, you can add features that are necessary for a particular cycle to the movement path on any formed section: stop, oriented stop, etc., change the type or value of feed, or skip the tool movement prepared by the former. Input parameter: Value (interface) - an object that implements the INCT_LatheCycleEvents interfaces. Described in detail in the article Turning cycle threading. , INCT_LatheCycleArcEvents (described below) No output parameters. |
Get_Events |
The function returns an object that implements the events associated with the loop generator (INCT_LatheCycleEvents, INCT_LatheCycleArcEvents ). No input parameters. |
Get_SignLongitudinal |
The function returns the sign of the longitudinal processing (integer). 1 - direction coincides with longitudinal axis, 0 - direction undefined; -1 - direction opposite to longitudinal axis. No input parameters. |
Get_SignTransverse |
The function returns the sign of the transversional processing (integer). 1 - direction coincides with transverse axis, 0 - direction undefined; -1 - direction opposite transverse axis. No input parameters. |
MakeWorkpath |
The method forms a cycle path according to specified parameters. The process of forming the path of movement:
INCT_LatheStockRemovalCycleFormer2 extends the capabilities of the former for the movement of the turning cycle along a given contour.
Method |
Set_PassReturnMethod |
This method sets the order of movement to the return point. Input parameter: Value (TNCPassReturnMethod) - order of movement to the return point. prmStepwise - For each iteration of the cycle, the return is performed first along the normal to the feed axis, and then along the normal to the processing axis; prmDirect - For each iteration of the cycle, the return is performed directly to the return point. No output parameters. |
Get_PassReturnMethod |
The function returns sets the order of movement to the return point. (TNCPassReturnMethod). No input parameters. |
Set_CutDepthCalcMethod |
Method for determining the depth of cut. Input parameter: Value (TNCCutDepthCalcMethod) - method for determining the depth of cut. cdcByStep - The depth of each cut is equal to or less (at the last iteration of the cycle) than the specified processing step; cdcByCount - The depth of each cut is calculated based on the specified number of repetitions of the cycle. No output parameters. |
Get_CutDepthCalcMethod |
The function returns method for determining the depth of cut (TNCCutDepthCalcMethod). No input parameters. |
Set_Count |
The method sets the number of repetitions of the cycle (for the method of determining the depth of cut - by the number of repetitions cdcByCount) Input parameter: Value (Integer) - number of repetitions. No output parameters. |
Get_Count |
The function returns the number of repetitions of the cycle (for the method of determining the depth of cut - by the number of repetitions cdcByCount ). No input parameters. |
Set_Offset |
This method sets the offset of the start point of contour processing on each pass. Input parameter: Value (Number) - offset of the start point of contour. No output parameters. |
Get_Offset |
The function returns the offset of the start point of contour processing on each pass No input parameters. |
Get_ContourStartPoint |
The function returns the coordinates of the contour start point, taking into account the allowance set in the former (TNC2DPoint) No input parameters. |
Get_ContourEndPoint |
The function returns the coordinates of the end point of the contour, taking into account the allowance set in the former (TNC2DPoint) No input parameters. |
INCT_LatheCycleArcEvents - an interface implemented in the interpreter that allows you to control the behavior of the turning cycle while building arcs. The interface consists of a single-event method, which is performed by moving the instrument along the arc trajectory within cycle former. Using the methods of the interface, you can add to the path of the movement on any formed section the features necessary for a specific cycle: stop, oriented stop, etc., change the type of feed, or skip the tool movement prepared by the former.
Interface method description:
Method |
Description of use |
OnArc |
The method will be executed before each tool movement in an arc during the formation of the cycle path. Input parameters: MoveType (TNCLatheCycleMoveType) - move type, see the description Turning cycle grooving; Input and output parameters: Center (TNC2DPoint) - the coordinates of the arc center ; Point (TNC2DPoint) - coordinate movement point; Radius (number) - arc radius; Feed (TNCFeedType) - feedrate type; Handled (boolean) - sign of moving inside the OnMove implementation (True - move completed, False - move not completed). If, after calling OnArc, the Handled parameter takes the value True, this means that the movement was performed inside the implementation of the OnArc method and the loop former does not add a move command to the tool path. If, after calling OnArc, the Handled parameter takes the value False, the former assumes that the movement was not performed within the implementation of the OnArc method and adds a command to the point of the tool movement path to the Point with feed Feed type. |
If necessary, override the values of the point of movement in an arc or feed, or to refuse to move (skip). For example, if you need to change the feed type to accelerated, when you return to the initial level, after turning the groove, then in the implementation of the OnArc method you need to change the value of the Feed parameter returned by the method to ffRapid on the condition MoveType = lmReturnToTopLevel (the feed type is described in the article OutStandardFeed ). If you need to move the tool to a point other than the one calculated by the cycle, you need to change the value of the Center, Point, Radius parameter returned by the OnArc method. If moving to a point calculated by the cycle is not necessary, then within the implementation of the OnArc method, you need to change the value of the Handled parameter to True. |
INCT_LatheStockRemovalCycleEvents - an interface implemented in the interpreter that allows you to control the behavior of the turning cycle. The interface consists of a single-event method, which is performed after receiving the cycle geometry and trajectory calculation cycle before. Using the interface method and the INCT_InterpreterState interface, you can get contour parameters from the NC-program and pass them to the cycle former for correct formation (for example, the processing direction, if it is set by the command in the contour path of NC-program).
Interface method description :
Method |
OnCalcContourGeometry |
The method will be executed after getting the contour geometry and before calculating the cycle path with the former. No parameters. |
Using the interface method and the INCT_InterpreterState interface, you can get contour parameters from the NC-program and pass them to the cycle former for correct formation (for example, the processing direction, if it is set by the command in the contour path of NC-program). |
INCT_LatheStockRemovalCycleEvents2 - an interface implemented in the interpreter that allows you to control the behavior of the turning cycle. Extends the interface INCT_LatheStockRemovalCycleEvents.
Method |
Description od use |
OnCalcNextStep |
The method is performed when calculating the tool path for each pass. It is used to change the step and offset used when calculating the next start point of the contour pass and the return point after the contour pass for the current iteration. Input parameters: Iteration (Integer) - pass number, starting from 1; PointType (TNCLSRPointType) - the type of contour points: ptProfilePoint - the point where the path starts; ptReturnPoint - the point of return after passing through the circuit. Input and output parameters: Step (Number) -step for calculating the current pass (Cutting axis); Offset (Number) - offset for calculating the current pass (Opposite axis). |
Using the interface method, you can set your own algorithm for calculating the start points of the path and return points after the path for each pass, using the step and offset at the current iteration. |
OnCalcNextPoint |
The method is performed when calculating the tool path for each pass. It is used to change the coordinates of the points where the path starts and returns after the path is passed, calculated for the current iteration. Input parameters: Iteration (Целое число) - pass number, starting from 1; PointType (TNCLSRPointType) - the type of contour points: ptProfilePoint - the point where the path starts; ptReturnPoint - the point of return after passing through the circuit. Input and output parameters: Point (TNC2DPoint) - координаты точки. |
Using the interface method, you can set your own algorithm for calculating the points of the beginning of a path along the contour and returning after passing along the contour for each pass, using the coordinates of the points at the current iteration. |
INCT_InterpreterState - interface implemented by the interpreter (the same object that implements the interface INCT_Interpreter), that allows you to save the current state of the interpreter and upload it to a newly created instance of the interpreter to correctly forming the trajectory of the contour.
For example, to form a contour trajectory, you need to know the current plane. To do this, the interpreter must create an object, save the current plane (Save method) to that object, and restore the current plane from the object transmitted to it (Load method) with a new instance of the interpreter.
Method |
Save |
The method should create an object that implements its own interface, store the current state data in the object, transfer the interface to the object at the output. No input parameters. Output parameter: State - interface IUnknown. |
To form the trajectory of the contour, you need to know the current plane set in the main NC program. When implementing the Save method, you need to keep the current plane in the object that is created inside the method. The link to the object will be transferred by the SprutCAM X kernel to a new instance of the interpreter, by calling the Load method. When you realize, you need to get the value of the current plane from the transferred object. |
Load |
The method should get its own interface from the object transmitted in the input setting, get the current state of the interpreter, necessary to form the trajectory of the contour. Input parameter: State - interface IUnknown . No output parameters. |
