G-code based operation, G-code based lathe operation
Set
NC program
Select
the interpreter
Press
"Run"
Get
the toolpath
images/download/attachments/84219065/SetNC_Eng.png
images/download/attachments/84219065/SelectInterpreter_Eng.png
images/download/attachments/84219065/RunCalc_Eng.png
images/download/thumbnails/84219065/GCodeMillToolPath.png
< G-code based operation > images/download/thumbnails/84219065/NCBasedMilling_Ico.bmp and < G-code based lathe operation> images/download/thumbnails/84219065/NCBasedLathe_Ico.png operations located in <Auxiliary> list. It can be also used for indexed and continuous processing at 4 and 5 coordinate machining centers. All available simulation types are supported, including additive manufacturing to simulate material layer buildup.
Note:
  • images/download/thumbnails/84219065/NCBasedMilling_Ico.bmp < G-code based operation > does not support the turning tool.
  • images/download/thumbnails/84219065/NCBasedLathe_Ico.png < G-code based lathe operation > supports only turning tool.
  • Both operations do not support Wire EDM machining.
These operations allow you to perform:
  • direct control of the machine simulation using G-codes;
  • check and optimize the NC program;
  • convert the text of the NC from one controller to another (for machines with identical kinematic scheme);
  • debug your own interpreter during its creation.
The toolpath is formed on the basis of the following operation parameters:
  • Specified NC text on the images/download/attachments/84219065/JobAssignment.png < Job assignment > parameters panel;
  • Selected interpreter on the images/download/attachments/84219065/Strategy.png < Strategy > parameters panel;
  • Assigned tool on the images/download/attachments/84219065/Tool.png < Tool > parameters panel.
images/download/thumbnails/84219065/NCFile.png < The NC text > can be written manually or can be loaded from an external file and edited, if necessary. The built-in text editor supports syntax highlighting of the main key structures of the CNC programming language, as well as a wide range of keyboard shortcuts for working with text.
More detailed information about the possibilities of working with the NC text is described in the section < Job assignment for G-code based operation, G-code based lathe operation >
images/download/thumbnails/84219065/SNCIFile.png < Interpreter file (*.snci) > defines the format of recognition of the controller commands in blocks of the NC program. The corresponding parameter specifies the full path to the selected interpreter. The parameter value can be entered manually as well as by using the file selection dialogue, which is accessed by using the images/download/thumbnails/84219065/FileDialogBtn.png entered button. During the selection process, selection process, a preview of the interpreter information is available (description, purpose, CNC system, authors, etc.):
images/download/attachments/84219065/InterpreterPreviewPane_Eng.png
The ability to select an interpreter from the container is supported.
Currently, interpreters of the following CNC systems are available for use:
Machine group
CNC system
Comment
Note
Milling
APT
Import toolpath only
Apt_Simplify_3D
ISO
Fanuc 30i
To simulate and import a toolpath
Haas VF-2
Heidenhain iTNC 530
NC210
An additional license is required
Sinumerik 840D
Tormach PCNC Mach3
Tormach PCNC PathPilot
Global control
Turn-milling
Sinumerik 840D
Okuma OSP-P300
Robot
Fanuc robot (R-30iB controller)
Kuka robot
Motoman robot
ABB robot
Note: All interpreters support command list generated by postprocessors in SprutCAM X distribution kit only.
"Import toolpath only" interpreters are not supported matching line NC code - trajectory of tool movement.
When you select an interpreter, pay attention to its purpose (the Purpose field in the Preview pane)
images/download/attachments/84219140/G-code_Purpose_Eng.png
The selected interpreter should be intended for simulation. Otherwise, the trajectory of the tool may be incorrect (shifted relative to the coordinate system of the workpiece, duplicated approaches/retracts, incorrect starting position, etc.).
images/download/thumbnails/84219065/MCD2CLDConversion.bmp < Use advanced toolpath transformation >- this parameter converts the NC toolpath from machine to geometric. Which, in turn, makes it possible to correct the toolpath using the robot axes map. If the setting is disabled, then the final toolpath is formed (as closely as possible repeating the one specified in the NC program), without the possibility of changing it.
images/download/thumbnails/84219065/PhysicGOTOStep.bmp < Step of physic movements dividing > - available only when using Use advanced toolpath transformation (see above). In this mode, at the first stage, the tool path is converted into a geometric curve. At the next stage, machine movements are rasterized with the step specified in the current parameter to ensure maximum similarity with the original toolpath. The smaller the value of the rasterization step, the higher the accuracy of construction and, accordingly, the similarity with the original toolpath.
images/download/thumbnails/84219065/InsertUnknown.bmp < Add unrecognized commands in the trajectory > - this parameter adds all commands of the control program not recognized by the interpreter to the toolpath. Unrecognized commands are added to the tool path description as a technology command parameter < INSERT > before the recognized commands.
Example of how the parameter "Add unrecognized commands in the trajectory" works
NC program
This parameter is disabled
This parameter is enabled
images/download/attachments/84219065/InsertUnknown_NC.png
Commands M107, E - are not recognized by the interpreter
images/download/attachments/84219065/InsertUnknown_ModeOff.png
images/download/attachments/84219065/InsertUnknown_ModeOn.png
images/download/attachments/84219065/Radius%D0%A1ompensationMode.bmp < Radius compensation mode > - A bility to disable or set an arbitrary compensation value on the tool radius.
Parameter value
Milling
Turning
images/download/thumbnails/84219065/CompensationOff.bmp Off
images/download/thumbnails/84219065/TRCMode_Off.png
Radius compensation is disabled.
Commands G40, G41, G42 are ignored
images/download/thumbnails/84219065/CRCMode_Off.png
Cutter radius compensation is disabled.
images/download/thumbnails/84219065/CompensationRadius.bmp Tool radius
images/download/thumbnails/84219065/TRCRMode_Radius.png
Radius compensation is equal to the tool radius
images/download/thumbnails/84219065/CRCRMode_Radius.png
Cutter Radius compensation is equal to the tool nose radius
images/download/thumbnails/84219065/CompensationControl.bmp Custom value
images/download/thumbnails/84219065/TRCMode_CustomValue.png
Radius compensation is determined by the specified arbitrary value.
images/download/thumbnails/84219065/CRCMode_CustomValue.png
Cutter radius compensation is determined by the specified arbitrary value.
Parameter
Milling
Turning
Note
images/download/thumbnails/84219065/ToolRadiusDelta.bmp < Tool radius delta >
images/download/thumbnails/84219065/TRCMode_Radius_Delta.png
Additional tool offset.
The total offset is calculated as the sum of the tool radius and the value of the additional offset.
images/download/thumbnails/84219065/CRCMode_Radius_Delta.png
The total offset is calculated as the sum of the tool nose radius and the value of the additional offset.
The setting is only available when using the images/download/thumbnails/84219065/CompensationRadius.bmp <Tool radius> value set as the radius compensation mode (see above)
images/download/thumbnails/84219065/ToolRadiusDelta.bmp < Compensation value >
images/download/thumbnails/84219065/TRCMode_CustomValue2.png
Arbitrary value for radius compensation.
By default, the value is equal to the tool radius — 50% Ø
Arbitrary value for cutter radius compensation.
By default, the value is equal to the tool nose radius — 50% Ø
The setting is only available when using the images/download/thumbnails/84219065/CompensationControl.bmp <Custom value> value set as the radius compensation mode (see above)
images/download/thumbnails/84219065/MillToolType.bmp < The tool > that will be processed is determined on the corresponding tab of the operation parameters window. When creating G-code based operations, it is assigned a default tool for appropriate processing (milling or turning).
Note: Currently, the tool number indicated in the NC text is not taken into account when selecting from the list of project or library tools. Due to the above feature, only the NC text in which the processing is carried out by one tool can be assigned as a job assignment for each such operation.
G-code based operation demo video
Keyboard shortcuts for working with NC text
Creating your own interpreter
