Hole protected probing parameters
images/download/attachments/95446750/image2022-4-5_19-13-35.png
Hole protected probing consist of the following steps:
  1. The tool moves the distance specified in the < Feed distance > and approaches the starting position of the cycle. Moving at "Approach feed";
  2. The tool approaches a point remote from the first touch point along its <Target vector> at the <Side clearance> distance but elevated at the < Top clearance > value + < Depth > value . Moving at "Long link feed" ;
  3. The tool is lowered by a distance equal to <Top clearance> value + <Depth> value . Moving at "Long link feed" ;
  4. T he tool approaches the first touch point (m oving at "Work feed" ) and then returns (m oving at "Long link feed" ) to previous position;
  5. The tool is lifted up by a distance equal to < Top clearance > value + < Depth > value . Moving at "Long link feed" ;
  6. The tool returns to the starting position;
  7. Steps 2-6 are repeated as many times as there are touch points for the cycle;
  8. The tool is lifted up by a distance equal to <Feed distance >.
Parameters:
CLDArray
Type
Description
CmdPrm.Int[-1]
Integer
Probing cycle type: Hole protected probing value = 4
CmdPrm.Int[-2]
Integer
CmdPrm.Flt[-50]
Double
Feed distance, distance to start position of cycle
CmdPrm.Flt[-51]
Double
Depth, distance from top side to center of touch points
CmdPrm.Flt[-52]
Double
Diameter of measured hole
CmdPrm.Flt[-55]
Double
Top clearance, distance from top side
CmdPrm.Flt[-56]
Double
Side clearance, approach distance to touch poin t
CmdPrm.Int[-59]
Integer
Cycle variant. 0 - rectangular mode, 1 - angular mode
CmdPrm.Flt[-60]
Double
Start angle (for cycle variant = 1). Starting angle of touch points
CmdPrm.Flt[-61]
Double
Angular step (for cycle variant = 1). R adial distance between touch points
CmdPrm.Int[-62]
Integer
Step count (for cycle variant = 1). Count of touch points
CmdPrm.Flt[-100]
Double
First touch point value along X-axis
CmdPrm. Flt [-101]
Double
First t ouch point value along Y-axis
CmdPrm. Flt [-102]
Double
First t ouch point value along Z-axis
CmdPrm.Flt[-103]
Double
First target vector value along X-axis
CmdPrm. Flt [-104]
Double
First target vector value along Y-axis
CmdPrm. Flt [-105]
Double
First target vector value along Z-axis
CmdPrm.Flt[-100-((N-1)*6)]
Double
Other touch point value along X-axis. N - number of touch point
CmdPrm.Flt[-101-((N-1)*6)]
Double
Other touch point value along Y-axis. N - number of touch point
CmdPrm.Flt[-102-((N-1)*6)]
Double
Other touch point value along Z-axis. N - number of touch point
CmdPrm.Flt[-103-((N-1)*6)]
Double
Other target vector value along X-axis . N - number of touch point
CmdPrm.Flt[-104-((N-1)*6)]
Double
Other target vector value along Y-axis . N - number of touch point
CmdPrm.Flt[-105-((N-1)*6)]
Double
Other target vector value along Z-axis . N - number of touch point
