Hole probing parameters
images/download/attachments/95446745/image2022-4-4_23-34-6.png
Hole probing consist of the following steps:
  1. I f the <Top clearance> parameter is checked:
    1. T he tool moves the distance specified in the < Feed distance > and approaches the starting point of the <Top clearance> position. Moving at "Approach feed";
    2. T he tool moves the distance specified in the <Top clearance > plus < Depth > value and approaches the center of hole (starting point of cycle) . Moving at "Long link feed" ;
  2. I f the <Top clearance> parameter is unchecked:
    1. T he tool moves the distance specified in the <Feed distance > and approaches the center of hole (starting point of cycle) according to depth . Moving at "Approach feed" ;
  3. The tool approaches the first touch point (m oving at "Work feed" ) along its inverted <Target vector> and then returns (m oving at "Long link feed" ) to the center point. This action is repeated as many times as there are touch points;
  4. I f the <Top clearance> parameter is checked: t he tool moves up a distance equal to the < Top clearance > value + < Depth > value. Moving at "Long link feed" ;
  5. T he tool retracts a distance to the <Feed distance > position. Moving at "Return feed" .
Parameters:
CLDArray
Type
Description
CmdPrm.Int[-1]
Integer
Probing cycle type: Hole probing value = 3
CmdPrm.Int[-2]
Integer
CmdPrm.Flt[-50]
Double
Feed distance, distance to start position of cycle
CmdPrm.Flt[-51]
Double
Depth, distance from top side to center of touch points
CmdPrm.Flt[-52]
Double
Diameter of measured hole
CmdPrm.Flt[-55]
Double
Top clearance, distance from top side
CmdPrm.Int[-59]
Integer
Cycle variant. 0 - rectangular mode, 1 - angular mode
CmdPrm.Flt[-60]
Double
Start angle (for cycle variant = 1). Starting angle of touch points
CmdPrm.Flt[-61]
Double
Angular step (for cycle variant = 1). R adial distance between touch points
CmdPrm.Int[-62]
Integer
Step count (for cycle variant = 1). Count of touch points
CmdPrm.Flt[-100]
Double
First touch point value along X-axis
CmdPrm. Flt [-101]
Double
First t ouch point value along Y-axis
CmdPrm. Flt [-102]
Double
First t ouch point value along Z-axis
CmdPrm.Flt[-103]
Double
First target vector value along X-axis
CmdPrm. Flt [-104]
Double
First target vector value along Y-axis
CmdPrm. Flt [-105]
Double
First target vector value along Z-axis
CmdPrm.Flt[-100-((N-1)*6)]
Double
Other touch point value along X-axis. N - number of touch point
CmdPrm.Flt[-101-((N-1)*6)]
Double
Other touch point value along Y-axis. N - number of touch point
CmdPrm.Flt[-102-((N-1)*6)]
Double
Other touch point value along Z-axis. N - number of touch point
CmdPrm.Flt[-103-((N-1)*6)]
Double
Other target vector value along X-axis . N - number of touch point
CmdPrm.Flt[-104-((N-1)*6)]
Double
Other target vector value along Y-axis . N - number of touch point
CmdPrm.Flt[-105-((N-1)*6)]
Double
Other target vector value along Z-axis . N - number of touch point
