Selection filter
Objects selection filter toolbar located at the bottom of the right pane of the main window.
When choosing among the many geometric objects in the graphics window, it is useful to limit the selectability of objects depending on their type (point, curve, mesh, surface, e.t.c.). Filter parameters can be set up by pressing the corresponding buttons on the toolbar. By left-clicking the chosen button the corresponding filter is toggled on and off.
  • images/download/attachments/84214586/select_points_button.jpg – Allow/Restrict selection of points;
  • images/download/attachments/84214586/select_curves_button.jpg – Allow/Restrict selection of curves;
  • images/download/attachments/84214586/select_meshes_button.jpg – Allow/Restrict selection of meshes;
  • images/download/attachments/84214586/select_faces_button.jpg – Allow/Restrict selection of surfaces;
  • images/download/attachments/84214586/select_edges_button.jpg – Allow/Restrict selection of edges;
  • images/download/attachments/84214586/select_vertices_button.jpg – Allow/Restrict selection of vertices.
System's main window
