Additional parameters
NCAction
<NCAction> element has one own parameters:
CLDArray
Type
Description
CmdPrm.Int[-1]
Integer
Probing cycle type: NCAction value = 1
CmdPrm.Int[-2]
Integer
Custom properties
Custom properties have their own parameter codes that are stored in cycles and <NCAction> element:
CLDArray
Type
Description
CmdPrm.Int[-10]
Integer
Set WCS offset - mode. 0 - Global (all G54-G59); 1 - One WCS (one of G54-G59); 2 - Parametrical offset (G10 L2 P1 XYZ); 3 - Local CS offset (G52 XYZ)
CmdPrm.Int[-11]
Integer
Set WCS offset - CS Number ( Set WCS offset - mode = 1 or 2).
CmdPrm.Int[-12]
Integer
Set offset of tool number - Tool number
CmdPrm.Int[-13]
Integer
Set offset of tool number - Corrector 1
CmdPrm.Int[-14]
Integer
Set offset of tool number - Corrector 2
CmdPrm.Int[-15]
Integer
Check for broken tool - Tool number
CmdPrm.Int[-16]
Integer
Check for broken tool - Corrector 1
CmdPrm.Int[-17]
Integer
Check for broken tool - Corrector 2
CmdPrm.Int[-18]
Integer
Calibrate the tool probe number - Probe number
CmdPrm.Int[-19]
Integer
Calibrate the tool probe number - Corrector 1
CmdPrm.Int[-20]
Integer
Calibrate the tool probe number - Corrector 2
CmdPrm.Int[-21]
Integer
Calibrate the part probe number - Probe number
CmdPrm.Int[-22]
Integer
Calibrate the part probe number - Corrector 1
CmdPrm.Int[-23]
Integer
Calibrate the part probe number - Corrector 2
CmdPrm.Int[-24]
Integer
Write to report - Component number
CmdPrm.Int[-25]
Integer
Write to report - Feature number
For <Custom property> element, in <Job assignment> tab of probing cycle operation you manually set the code for the parameter to be stored in CLData and you can also set the type of the parameter. Custom parameter code must not be repeated with other codes.
images/download/attachments/95446808/image2022-4-6_0-30-4.png
Probe On/Off
The cycle on and off commands has parameters:
CLDArray
Type
Description
CmdPrm.Int[-1]
Integer
Probing cycle type: Cycle On/Off value = 0
CmdPrm.Int[-2]
Integer
Cycle On/Off SubCode = -500
CmdPrm.Bol[-3]
Boolean
On/Off mode. True is "On", false is "Off"
