Triple wall external corner probing parameters
images/download/attachments/95446801/image2022-4-28_17-46-32.png images/download/attachments/95446801/image2022-4-5_23-23-48.png
Triple wall external corner probing consist of the following steps:
  1. The tool moves the distance specified in the < Feed distance > and approaches the starting point of the measurement cycle that is the intersection of touch point on first wall and touch point on second wall at a distance specified in <Clearance 1>, <Clearance 2> , respectively, along orthogonal direction of their vectors and the intersection point is raised by the distance specified in the <Top clearance> + <Depth> . Moving at "Approach feed";
  2. The tool approaches a point remote from touch point on first side along its < Target vector > at the < C learance 1 > distance (m oving at "Long link feed" ) and approaches touch point of the first side (moving at "Work feed") and then returns (m oving at "Long link feed" ) to previous position ;
  3. The tool returns to the starting point. M oving at "Long link feed";
  4. The tool approaches a point remote from touch point on second side along its < Target vector > at the < C learance 2 > distance (m oving at "Long link feed" ) and approaches touch point of the second side (moving at "Work feed") and then returns (m oving at "Long link feed" ) to previous position ;
  5. The tool returns to the starting point. M oving at "Long link feed";
  6. The tool approaches a point remote from touch point on top side along its < Target vector > at the <Top clearance > distance (m oving at "Long link feed" ) and approaches touch point of the top side (moving at "Work feed") and then returns (m oving at "Long link feed" ) to previous position ;
  7. The tool returns to the starting point. M oving at "Long link feed";
  8. The tool is lifted up by a distance equal to <Feed distance >.
Parameters:
CLDArray
Type
Description
CmdPrm.Int[-1]
Integer
Probing cycle type: Double wall external corner probing value = 16
CmdPrm.Int[-2]
Integer
CmdPrm.Flt[-50]
Double
Feed distance, distance to start position of cycle
CmdPrm.Flt[-51]
Double
Depth, distance from top side to touch point of fisrt and second wall
CmdPrm.Flt[-56]
Double
Clearance 1, approach distance to touch poin t on first side
CmdPrm.Flt[-57]
Double
Clearance 2, approach distance to touch poin t on second side
CmdPrm.Flt[-58]
Double
Top clearance, approach distance to touch poin t on top side
CmdPrm.Flt[-100]
Double
Touch point on first wall value along X-axis
CmdPrm. Flt [-101]
Double
T ouch point on first wall value along Y-axis
CmdPrm. Flt [-102]
Double
T ouch point on first wall value along Z-axis
CmdPrm.Flt[-103]
Double
T arget vector of touch point on first wall value along X-axis
CmdPrm. Flt [-104]
Double
T arget vector of touch point on first wall value along Y-axis
CmdPrm. Flt [-105]
Double
T arget vector of touch point on first wall value along Z-axis
CmdPrm.Flt[-106]
Double
T ouch point on second wall value along X-axis
CmdPrm. Flt [-107]
Double
T ouch point on second wall value along Y-axis
CmdPrm. Flt [-108]
Double
T ouch point on second wall value along Z-axis
CmdPrm.Flt[-109]
Double
T arget vector of touch point on second wall value along X-axis
CmdPrm. Flt [-110]
Double
T arget vector of touch point on second wall value along Y-axis
CmdPrm. Flt [-111]
Double
T arget vector of touch point on second wall value along Z-axis
CmdPrm.Flt[-112]
Double
T ouch point on top wall value along X-axis
CmdPrm. Flt [-113]
Double
T ouch point on top wall value along Y-axis
CmdPrm. Flt [-114]
Double
T ouch point on top wall value along Z-axis
CmdPrm.Flt[-115]
Double
T arget vector of touch point on top wall value along X-axis
CmdPrm. Flt [-116]
Double
T arget vector of touch point on top wall value along Y-axis
CmdPrm. Flt [-117]
Double
T arget vector of touch point on top wall value along Z-axis
