Internal rectangle probing parameters
images/download/attachments/95446757/image2022-4-5_18-44-27.png images/download/attachments/95446757/image2022-4-5_18-44-49.png
Internal rectangle probing consist of the following steps:
  1. I f the <Top clearance> parameter is checked:
    1. T he tool moves the distance specified in the < Feed distance > and approaches the starting point of the <Top clearance> position. Moving at "Approach feed";
    2. T he tool moves the distance specified in the <Top clearance > plus < Depth > value and approaches the center of sides (starting point of cycle) . Moving at "Long link feed" ;
  2. I f the <Top clearance> parameter is unchecked:
    1. T he tool moves the distance specified in the <Feed distance > and approaches the center of sides (starting point of cycle) according to depth . Moving at "Approach feed" ;
  3. The tool approaches the first touch point (m oving at "Work feed" ) along its inverted <Target vector> and then returns (m oving at "Long link feed" ) to the center point. This action is repeated 3 more times for each touch points;
  4. I f the <Top clearance> parameter is checked: t he tool moves up a distance equal to the < Top clearance > value + < Depth > value. Moving at "Long link feed" ;
  5. T he tool retracts a distance to the <Feed distance > position. Moving at "Return feed" .
Parameters:
CLDArray
Type
Description
CmdPrm.Int[-1]
Integer
Probing cycle type: Internal rectangle probing value = 6
CmdPrm.Int[-2]
Integer
CmdPrm.Flt[-50]
Double
Feed distance, distance to start position of cycle
CmdPrm.Flt[-51]
Double
Depth, distance from top side to center of touch points
CmdPrm.Flt[-53]
Double
Width 1, distance from Touch point 1 to Touch point 2
CmdPrm.Flt[-54]
Double
Width 2, distance from Touch point 3 to Touch point 4
CmdPrm.Flt[-55]
Double
Top clearance, distance from top side
CmdPrm.Flt[-100]
Double
First touch point value along X-axis
CmdPrm. Flt [-101]
Double
First t ouch point value along Y-axis
CmdPrm. Flt [-102]
Double
First t ouch point value along Z-axis
CmdPrm.Flt[-103]
Double
First target vector value along X-axis
CmdPrm. Flt [-104]
Double
First target vector value along Y-axis
CmdPrm. Flt [-105]
Double
First target vector value along Z-axis
CmdPrm.Flt[-106]
Double
Second touch point value along X-axis
CmdPrm. Flt [-107]
Double
Second t ouch point value along Y-axis
CmdPrm. Flt [-108]
Double
Second t ouch point value along Z-axis
CmdPrm.Flt[-109]
Double
Second target vector value along X-axis
CmdPrm. Flt [-110]
Double
Second target vector value along Y-axis
CmdPrm. Flt [-111]
Double
Second target vector value along Z-axis
CmdPrm.Flt[-112]
Double
Third touch point value along X-axis
CmdPrm. Flt [-113]
Double
Third t ouch point value along Y-axis
CmdPrm. Flt [-114]
Double
Third t ouch point value along Z-axis
CmdPrm.Flt[-115]
Double
Third target vector value along X-axis
CmdPrm. Flt [-116]
Double
Third target vector value along Y-axis
CmdPrm. Flt [-117]
Double
Third target vector value along Z-axis
CmdPrm.Flt[-118]
Double
Fourth touch point value along X-axis
CmdPrm. Flt [-119]
Double
Fourth t ouch point value along Y-axis
CmdPrm. Flt [-120]
Double
Fourth t ouch point value along Z-axis
CmdPrm.Flt[-121]
Double
Fourth target vector value along X-axis
CmdPrm. Flt [-122]
Double
Fourth target vector value along Y-axis
CmdPrm. Flt [-123]
Double
Fourth target vector value along Z-axis
