Project operator
The Project operator allows you to get access from the code of the postprocessor to the information about the SprutCAM project (information that relates to the entire project, and not to individual operations), which lies in the CLData. Operator syntax is as follows.
Project.Ptr|Str|Int|Flt["ParameterName"]
Here, Project is the key word to access SprutCAM project level parameters.
Ptr or Str or Int or Flt is a keyword that defines the form in which you want to represent the value of a property — as a string, as an integer, as a floating point number, or as a pointer to a property. Read more about this in Named CLData parameters topic.
Further in square brackets follows the string identifier of the property whose value is to be obtained. It can be a string constant, as shown here, as well as any string expression or variable.
For a description of possible properties and their values, see the appendix in the Project information in CLData article.
Consider an example of obtaining information about the workpiece using this operator.
sub PrintAllWorkpiece
i:
Integer
j:
Integer
px, py, pz, pv:
Real
for
i =
to
Project
Ptr["Parts"].ItemCount
do
begin
Output "( Part" + str(i) + ".Workpiece )"
for
j =
to
Project
Ptr["Parts"].Item[i].Ptr["Workpiece"].ItemCount
do
begin
Output "( Primitive " + str(j) + " )"
case
Project
Ptr["Parts"].Item[i].Ptr["Workpiece"].Item[j].Int["PrimitiveType"]
of
0
begin
!Unknown
Output "(
Type
: Unknown )"
end
begin
!Empty
Output "(
Type
: Empty workpiece )"
end
2
begin
!Faces
Output "(
Type
: Faces )"
px = Project
Ptr["Parts"].Item[i].Ptr["Workpiece"].Item[j].Flt["Box
Min
X"]
py = Project
Min
Y"]
pz = Project
Min
Z"]
Output "( Min point: (" + str(px) + ", " + str(py) + ", " + str(pz) + " ) )"
px = Project
Max
X"]
py = Project
Max
Y"]
pz = Project
Max
Z"]
Output "( Max point: (" + str(px) + ", " + str(py) + ", " + str(pz) + " ) )"
end
3
begin
!Casting
Output "(
Type
: Casting )"
pv = Project
Ptr["Parts"].Item[i].Ptr["Workpiece"].Item[j].Flt["Stock"]
Output "( Stock: " + str(pv) + " )"
px = Project
Min
X"]
py = Project
Min
Y"]
pz = Project
Min
Z"]
px = Project
Max
X"]
py = Project
Max
Y"]
pz = Project
Max
Z"]
end
4
begin
!Box
Output "(
Type
: Box )"
px = Project
Ptr["Parts"].Item[i].Ptr["Workpiece"].Item[j].Flt["Min
X"]
py = Project
Y"]
pz = Project
Z"]
px = Project
Ptr["Parts"].Item[i].Ptr["Workpiece"].Item[j].Flt["Max
X"]
py = Project
Y"]
pz = Project
Z"]
end
5
begin
!RevBody
Output "(
Type
: Turn envelope )"
px = Project
Ptr["Parts"].Item[i].Ptr["Workpiece"].Item[j].Flt["Origin
X"]
py = Project
Y"]
pz = Project
Z"]
Output "( Origin: (" + str(px) + ", " + str(py) + ", " + str(pz) + " ) )"
px = Project
Ptr["Parts"].Item[i].Ptr["Workpiece"].Item[j].Flt["Axis
X"]
py = Project
Y"]
pz = Project
Z"]
Output "( Axis: (" + str(px) + ", " + str(py) + ", " + str(pz) + " ) )"
end
begin
!Cylinder
Output "(
Type
: Cylinder )"
px = Project
X"]
py = Project
Y"]
pz = Project
Z"]
px = Project
X"]
py = Project
Y"]
pz = Project
Z"]
pv = Project
Ptr["Parts"].Item[i].Ptr["Workpiece"].Item[j].Flt["HMin"]
Output "( Min level: " + str(pv) + " )"
pv = Project
Ptr["Parts"].Item[i].Ptr["Workpiece"].Item[j].Flt["HMax"]
Output "( Max level: " + str(pv) + " )"
pv = Project
Ptr["Parts"].Item[i].Ptr["Workpiece"].Item[j].Flt["ROut"]
Output "( Outer radius: " + str(pv) + " )"
end
7
begin
!Tube
Output "(
Type
: Tube )"
px = Project
X"]
py = Project
Y"]
pz = Project
Z"]
px = Project
X"]
py = Project
Y"]
pz = Project
Z"]
pv = Project
pv = Project
pv = Project
pv = Project
Ptr["Parts"].Item[i].Ptr["Workpiece"].Item[j].Flt["RInn"]
Output "( Inner radius: " + str(pv) + " )"
end
8
begin
!Prism
Output "(
Type
: Prism )"
px = Project
X"]
py = Project
Y"]
pz = Project
Z"]
px = Project
X"]
py = Project
Y"]
pz = Project
Z"]
pv = Project
pv = Project
end
9
begin
!PolygonalPrism
Output "(
Type
: Polygonal prism )"
px = Project
X"]
py = Project
Y"]
pz = Project
Z"]
px = Project
X"]
py = Project
Y"]
pz = Project
Z"]
pv = Project
Ptr["Parts"].Item[i].Ptr["Workpiece"].Item[j].Int["CornerCount"]
Output "( Corner count: " + str(pv) + " )"
pv = Project
Output "( Inscribed radius: " + str(pv) + " )"
pv = Project
Ptr["Parts"].Item[i].Ptr["Workpiece"].Item[j].Flt["Angle"]
Output "( Angle around axis: " + str(pv) + " )"
pv = Project
pv = Project
end
else
begin
Output "(
Type
: Something
else
end
end
end
end
subend
The result of this subroutine may be the following text block.
( Part1.Workpiece )
( Primitive
( Type: Tube )
( Origin: (
0
0
117.5
( Axis: (
0
0
( Min level: -
149.5
( Max level:
149.5
( Outer radius:
66
( Inner radius:
29
( Primitive
2
( Type: Cylinder )
( Origin: (
0
0
117.5
( Axis: (
0
0
( Min level: -
147.5
( Max level:
147.5
( Outer radius:
64
( Primitive
3
( Type: Turn envelope )
( Origin: (
0
0
117.5
( Axis: (
0
0
( Primitive
4
( Type: Box )
( Min point: (-
64
64
30
( Max point: (
64
64
265
( Primitive
5
( Type: Casting )
( Stock:
( Min point: (-
65
65
31
( Max point: (
65
65
266
( Primitive
( Type: Faces )
( Min point: (-
54
54
30
( Max point: (
54
54
265
( Primitive
7
( Type: Polygonal prism )
( Origin: (
0
0
117.5
( Axis: (
0
( Corner count:
( Inscribed radius:
160.786
0
( Min level: -
64
( Max level:
64
( Primitive
8
( Type: Empty workpiece )
