<GMA> array
Use the predefined <GMA> array to conveniently process multiaxis movement <MULTIGOTO> command in the technology program and in the mask of the command. <GMA> array is initialized directly before the <MULTIGOTO> technology command is processed.
Every item of <GMA> array corresponds to an controlled coordinate of the machine scheme. Items of the <GMA> array can be added manually using the Postprocessor generator interface or imported directly from SprutCAM machine scheme.
Optionally, coordinates can be added to <GMA> array during postprocessor execution using following operator syntax:
GMA(<AxisName> {,<RegisterName>})
Here <AxisName> is a legal expression that returns a string. The new coordinate name will be set to <AxisName>, use it to access the new item. Optional paramter <RegisterName> is the name of the register associated with the new.
Example:
GMA(“AxisXPos”)
Use the name of a coordinate to access it's <GMA> properties:
GMA[<AxisName>].<Property>
Or for masks:
<Axisname>.<Property>
Here <AxisName> is a legal string expression that must be a valid coordinate name. In the following example the name of the coordinate <AxisXPos> is used to access the coordinate current value:
GMA[“AxisXPos”].Vn ! Vn – coordinate current value
GMA Structure
<GMA> array item has the following structure:
GMA[<AxisName>].OutFlag
GMA[<AxisName>].Vn
GMA[<AxisName>].Vp
GMA[<AxisName>].Axis
GMA[<AxisName>].Reg
GMA[<AxisName>].TurnCount
GMA[<AxisName>].Dir
  • <GMA[<AxisName>].OutFlag> is an <Integer> field that is assigned values 1 or 0. Use this flag to determine whether the coordinate named <AxisName> is listed in the given <MULTIGOTO> command. <GMA[<AxisName>].OutFlag> has the value of 1 (the flag is set) if there is a coordinate named is <AxisName> in the given <MULTIGOTO> command, otherwise the flag is 0.
  • <GMA[<AxisName>].Vn> is a <Real> field and it's value is the new value of the coordinate <AxisName> set by <MULTIGOTO> command. Use the <Vn> field to read or set the new coordinate value.
  • <GMA[<AxisName>].Vp> is a <Real> field that contains the value of <AxisName> coordinate assigned by the previous <MULTIGOTO> command. Use the <Vp> field to read or set the previous coordinate value.
  • <GMA[<AxisName>].Axis> is a <String> field that is the name of the coordinate and is equal to <AxisName>. The field is read-only.
  • <GMA[<AxisName>].Reg> is a <String> field and it's value is the name of the register associated with the coordinate. The field is read-only.
  • <GMA[<AxisName>].TurnCount> is an <Integer> field that is assigned the number of full turns of a rotatable axis. The field is read-only.
  • <GMA[<AxisName>].Dir> is an <Integer> value that is assigned +1 if the value of the coordinate is increasing, otherwise it is set to -1. The field is read-only.
Use <TurnCount> and <Dir> fields to process the movement of rotatable axes. SprutCAM passes the movements of rotatable axes in absolute values, whereas some NC-systems accept only values in bound ranges like 0º to 360º or 180º до -180º for those coordinates. Use the <Machine axes parameters> dialog to define the bounds and ranges parameters of rotatable axes. If angle reduction is defined for a given coordinate then when processing <MULTIGOTO> command the system will reduce the coordinate value <Vn> to specified range, assign the <TurnCount> field the number of full revolutions of the coordinate and set the sign of the <Dir> field depending on the previous (not reduced) value of the coordinate.
Here are a few examples illustrating how the system initializes the properties of <GMA> array items when processing <MULTIGOTO> technology command. Suppose rotatable axis C (<AxisCPos>) is bound to values from 0º to 360º.
  1. Command:
MULTIGOTO COUNT 4, AxisXPos(18) 80, AxisYPos(20) 19.877,
AxisZPos(22) -200, AxisCPos(24) 0
<GMA> array for the <MULTIGOTO> command
Coordinate name
OutFlag
Vn
Vp
Axis
Reg
TurnCount
Dir
AxisXPos
“AxisXPos”
“X”
AxisYPos
“AxisYPos”
”Y”
AxisZPos
“AxisZPos”
”Z”
AxisCPos
“AxisCPos”
”C”
«-//-//-» sign indicates that the values of the properties of coordinates cannot be determined because there is no information of the previous command.
  1. Command:
MULTIGOTO COUNT 1, AxisCPos(24) 270
Coordinate name
OutFlag
Vn
Vp
Axis
Reg
TurnCount
Dir
AxisXPos
0
80
80
“AxisXPos”
”X”
AxisYPos
0
19.877
19.877
“AxisYPos”
”Y”
AxisZPos
0
-200
-200
“AxisZPos”
”Z”
AxisCPos
0
“AxisCPos”
”C”
0
+1
  1. Command:
MULTIGOTO COUNT 2, AxisZPos(22) 250, AxisCPos(24) -745
Coordinate name
OutFlag
Vn
Vp
Axis
Reg
TurnCount
Dir
AxisXPos
0
80
80
“AxisXPos”
”X”
AxisYPos
0
19.877
19.877
“AxisYPos”
”Y”
AxisZPos
-200
“AxisZPos”
”Z”
AxisCPos
270
“AxisCPos”
”C”
2
-1
In the last example the system applied angle reduction for the <AxisCPos(C)> coordinate. The value passed by SprutCAM «-745 º» is reduced to the range from 0º to 360º by the following rules:
TurnCount = |(Vn’ - Vp’) \ 360|
TurnCount = |(-745 -270) \ 360| = 2
Dir = Sgn(Vn’-Vp’)
Dir = Sgn(-745 -270) = -1
Vn = Vn’ – (Vn’ \ 360)*360, if Vn’ > 360
Vn = Vn’ – (Vn’ \ 360)*360 + 360, if Vn’ < 0
Vn = -745 – (-745\360)*360 + 360 = 335
<Vn’> – the current not reduced value of the coordinate, <Vp’> – previous not reduced value of the coordinate.
The following is an example of a simple <MULTIGOTO> command program that uses the <GMA> array:
program MultiGoto
! Use the GMA fields to assign
! respective registers their new values
if GMA["AxisXPos"].OutFlag>0 then
X = GMA["AxisXPos"].Vn
if GMA["AxisYPos"].OutFlag>0 then
Y = GMA["AxisYPos"].Vn
if GMA["AxisZPos"].OutFlag>0 then
Z = GMA["AxisZPos"].Vn
if GMA["AxisCPos"].OutFlag>0 then
C = GMA["AxisCPos"].Vn
! Output the formed values into the NC-program
OutBlock
end
Predefined functions
<MultiGoto> command
Masks
