Groove probing parameters
Groove probing consist of the following steps:
I f the <Top clearance> parameter is checked:
T he tool moves the distance specified in the < Feed distance > and approaches the starting point of the <Top clearance> position. Moving at "Approach feed";
T he tool moves the distance specified in the <Top clearance > plus < Depth > value and approaches the center of touch points (starting point of cycle) . Moving at "Long link feed" ;
I f the <Top clearance> parameter is unchecked:
T he tool moves the distance specified in the <Feed distance > and approaches the center of touch points (starting point of cycle) according to depth . Moving at "Approach feed" ;
The tool approaches the first touch point (m oving at "Work feed" ) along its inverted <Target vector> and then returns (m oving at "Long link feed" ) to the center point. This action is repeated for the second touch point ;
I f the <Top clearance> parameter is checked: t he tool moves up a distance equal to the < Top clearance > value + < Depth > value. Moving at "Long link feed" ;
T he tool retracts a distance to the <Feed distance > position. Moving at "Return feed" .
Parameters:
Type |
Description |
CmdPrm.Int[-1] |
Integer |
Probing cycle type: Groove probing value = 11 |
CmdPrm.Int[-2] |
Integer |
CmdPrm.Flt[-50] |
Double |
CmdPrm.Flt[-51] |
Double |
Depth, distance from top side to center of touch points |
CmdPrm.Flt[-53] |
Double |
Width, distance from Touch point 1 to Touch point 2 |
CmdPrm.Flt[-55] |
Double |
Top clearance, distance from top side |
CmdPrm.Flt[-100] |
Double |
First touch point value along X-axis |
CmdPrm. Flt [-101] |
Double |
First t ouch point value along Y-axis |
CmdPrm. Flt [-102] |
Double |
First t ouch point value along Z-axis |
CmdPrm.Flt[-103] |
Double |
First target vector value along X-axis |
CmdPrm. Flt [-104] |
Double |
First target vector value along Y-axis |
CmdPrm. Flt [-105] |
Double |
First target vector value along Z-axis |
CmdPrm.Flt[-106] |
Double |
Second touch point value along X-axis |
CmdPrm. Flt [-107] |
Double |
Second t ouch point value along Y-axis |
CmdPrm. Flt [-108] |
Double |
Second t ouch point value along Z-axis |
CmdPrm.Flt[-109] |
Double |
Second target vector value along X-axis |
CmdPrm. Flt [-110] |
Double |
Second target vector value along Y-axis |
CmdPrm. Flt [-111] |
Double |
Second target vector value along Z-axis |
