Web probing (three points) parameters
Web probing (three points) consist of the following steps:
The tool moves the distance specified in the < Feed distance > and approaches the starting position of the cycle. Moving at "Approach feed";
The tool approaches a point remote from the left touch point along its <Target vector> at the <Side clearance> distance but elevated at the < Top clearance > value + < Depth > value . Moving at "Long link feed" ;
The tool is lowered by a distance equal to <Top clearance> value + <Depth> value . Moving at "Long link feed" ;
T he tool approaches the left touch point (m oving at "Work feed" ) and then returns (m oving at "Long link feed" ) to previous position;
The tool is lifted up by a distance equal to < Top clearance > value + < Depth > value . Moving at "Long link feed" ;
The tool returns to the starting position;
Steps 2-6 are repeated for the right touch point;
T he tool approaches the middle touch point (m oving at "Work feed" ) and then returns (m oving at "Long link feed" ) to previous position;
The tool is lifted up by a distance equal to <Feed distance >.
Parameters:
Type |
Description |
CmdPrm.Int[-1] |
Integer |
Probing cycle type: Web probing (three points) value = 10 |
CmdPrm.Int[-2] |
Integer |
CmdPrm.Flt[-50] |
Double |
CmdPrm.Flt[-51] |
Double |
Depth, distance from middle side to center of left and right point |
CmdPrm.Flt[-53] |
Double |
Width, distance from left point to right point |
CmdPrm.Flt[-56] |
Double |
Side clearance, approach distance to right/left touch poin t |
CmdPrm.Flt[-57] |
Double |
Middle clearance, approach distance to middle touch poin t |
CmdPrm.Flt[-100] |
Double |
Left touch point value along X-axis |
CmdPrm. Flt [-101] |
Double |
Left t ouch point value along Y-axis |
CmdPrm. Flt [-102] |
Double |
Left t ouch point value along Z-axis |
CmdPrm.Flt[-103] |
Double |
Left target vector value along X-axis |
CmdPrm. Flt [-104] |
Double |
Left target vector value along Y-axis |
CmdPrm. Flt [-105] |
Double |
Left target vector value along Z-axis |
CmdPrm.Flt[-106] |
Double |
Right touch point value along X-axis |
CmdPrm. Flt [-107] |
Double |
Right t ouch point value along Y-axis |
CmdPrm. Flt [-108] |
Double |
Right t ouch point value along Z-axis |
CmdPrm.Flt[-109] |
Double |
Right target vector value along X-axis |
CmdPrm. Flt [-110] |
Double |
Right target vector value along Y-axis |
CmdPrm. Flt [-111] |
Double |
Right target vector value along Z-axis |
CmdPrm.Flt[-112] |
Double |
Middle touch point value along X-axis |
CmdPrm. Flt [-113] |
Double |
Middle t ouch point value along Y-axis |
CmdPrm. Flt [-114] |
Double |
Middle t ouch point value along Z-axis |
CmdPrm.Flt[-115] |
Double |
Middle target vector value along X-axis |
CmdPrm. Flt [-116] |
Double |
Middle target vector value along Y-axis |
CmdPrm. Flt [-117] |
Double |
Middle target vector value along Z-axis |
