Groove probing protected parameters
Groove probing protected consist of the following steps:
The tool moves the distance specified in the < Feed distance > and approaches the starting position of the cycle. Moving at "Approach feed";
The tool approaches a point remote from the first touch point along its <Target vector> at the <Side clearance> distance but elevated at the < Top clearance > value + < Depth > value . Moving at "Long link feed" ;
The tool is lowered by a distance equal to <Top clearance> value + <Depth> value . Moving at "Long link feed" ;
T he tool approaches the first touch point (m oving at "Work feed" ) and then returns (m oving at "Long link feed" ) to previous position;
The tool is lifted up by a distance equal to < Top clearance > value + < Depth > value . Moving at "Long link feed" ;
The tool returns to the starting position;
Steps 2-6 are repeated for second touch point ;
The tool is lifted up by a distance equal to <Feed distance >.
Parameters:
Type |
Description |
CmdPrm.Int[-1] |
Integer |
Probing cycle type: Groove probing protected value = 12 |
CmdPrm.Int[-2] |
Integer |
CmdPrm.Flt[-50] |
Double |
CmdPrm.Flt[-51] |
Double |
Depth, distance from top side to center of touch points |
CmdPrm.Flt[-53] |
Double |
Width, distance from Touch point 1 to Touch point 2 |
CmdPrm.Flt[-55] |
Double |
Top clearance, distance from top side |
CmdPrm.Flt[-56] |
Double |
Side clearance, approach distance to touch poin t 1/ touch poin t 2 |
CmdPrm.Flt[-100] |
Double |
First touch point value along X-axis |
CmdPrm. Flt [-101] |
Double |
First t ouch point value along Y-axis |
CmdPrm. Flt [-102] |
Double |
First t ouch point value along Z-axis |
CmdPrm.Flt[-103] |
Double |
First target vector value along X-axis |
CmdPrm. Flt [-104] |
Double |
First target vector value along Y-axis |
CmdPrm. Flt [-105] |
Double |
First target vector value along Z-axis |
CmdPrm.Flt[-106] |
Double |
Second touch point value along X-axis |
CmdPrm. Flt [-107] |
Double |
Second t ouch point value along Y-axis |
CmdPrm. Flt [-108] |
Double |
Second t ouch point value along Z-axis |
CmdPrm.Flt[-109] |
Double |
Second target vector value along X-axis |
CmdPrm. Flt [-110] |
Double |
Second target vector value along Y-axis |
CmdPrm. Flt [-111] |
Double |
Second target vector value along Z-axis |
