Changing properties of an existing coordinate system
To open the coordinate system properties window press the  Edit active CS menu item on the coordinate systems panel.
The coordinate system properties window is shown below:
The CS name can be changed in this window, as well as its <Color> and <Comment>.
To move or rotate coordinate system, define the displacement value for the <X>, <Y>, <Z> axes or corresponding rotation angles. These values are relative to the <Parent> or <Global> coordinate system depend on the active tab.
Geometrical coordinate systems
