Point Pick-and-Place
It's based on the Pick-and-place operation.
The job assignment
is built on nodal points. At points, a position is set for moving the machine. By adding and removing points, you can set the desired movement of the part.
A job assignment consists of several types of points:
Start point
Pick point
Move point (relative to Pick point)
Move point (relative to Place point)
Place point
End pointThese points can be used to construct a chain of trajectories.
Start point
It is read-only. This is the end point of the previous operation
Pick point
The grip position of the part.
Properties:
Pick position is defined in geometry coordinate system with additional transformations.
if Pick only is selected, the trajectory stops at this point.
Axes - machine axis at the current point.When changing axes, two buttons appear:
- moves the point to the tip of the machine
- returns previous values
- 360/+360
Flip - controls flips in the robot
The page has buttons “Add position before” and Add position after” to add intermediate points. By default, points are added relative to the selected one.
if you change the initial position of the part, then by default this point will also move.
Properties:
Fix vX - enable 6 axis edit mode:
Motion type - is set by what type to move to the point:MultiGoto - Multi coordinate movement
PhysicGoto - Physical machine axes movement
Avoid collisions - Collision avoidance movement
Differs from the previous point in that the point moves with the end position of the part.
Place point
Position where the part should be placed.
The position where the part is to be placed is defined by the workpiece connector and workpiece setup. All movements of the gripper is generated in the defined workpiece coordinate system.
End point
This is a return to the tool change point. If it is off, then the trajectory ends at a Place point.
Clearance point
Using these points you can define the length and the direction for the engage/retract movements to the pick and/or place positions.
How to drag points in interactive can be found in Point Welding operation
Machine requirements for part moving operations
