Point welding operation
Operation can be used to
Tack weld and
Spot weld.
Job assignment
In the strategy tab, you need to select the type of welding:
For both types the job assignment is the same.
The job assignment
consists of two types of points:
Weld Point
Move Point
These points can be used to construct a chain of trajectories:
Drag points
These points can be moved by dragging.
They attach to faces
, curves
, splines
, edges
, vertices
. Tool axis rotates automatically when attached.
Move points can be easily moved using Smart snap
Position of the point can also be specified as an offset from the auxiliary yellow point.
To do this, first select the yellow point:
You can also rotate the axis vector by dragging the visual vector:
Point parameters
Points contains the following parameters:
Weld Point
Move Point
Caption - point name
Position - point coordinates.
Angles - tool axis inclination angle at point
Fix vZ - if enabled point vector does not change when dragged
Fix vX - enable 6 axis edit mode:
Motion type - is set by what type to move to the point:
MultiGoto - Multi coordinate movement
PhysicGoto - Physical machine axes movement
Avoid collisions - Collision avoidance movement
Axes - machine axis at the current point.
When changing axes, two buttons appear:
- moves the point to the tip of the machine
- returns previous values
- 360/+360
Flip - controls flips in the robot
Auxiliary Point
Weld point also contains additional auxiliary points:
Clearence
Engage
Retract
