List of interpreters
Currently, interpreters of the following CNC systems are available for use:
Machine group |
CNC system |
Comment |
Note |
Milling |
APT |
Import toolpath only |
Apt_Simplify_3D |
ISO |
Global control |
An additional license is required |
Fanuc 30i |
To simulate and import a toolpath |
Haas VF-2 |
Heidenhain iTNC 530 |
Mazatrol SmoothG |
NC210 |
Sinumerik 840D |
Tormach PCNC Mach3 |
Tormach PCNC PathPilot |
Turning |
Mazatrol SmoothC |
Turn-milling |
Fanuc 21i |
NC220 |
Sinumerik 840D |
Okuma OSP-P300 |
Robot |
Fanuc robot (R-30iB controller) |
Kuka robot |
Motoman robot |
ABB robot |
Nachi robot (AW Format) |
Note: All interpreters support command list generated by postprocessors in SprutCAM X distribution kit only.
"Import toolpath only" interpreters are not supported matching line NC code - trajectory of tool movement.
When you select an interpreter, pay attention to its purpose (the Purpose field in the Preview pane)
The selected interpreter should be intended for simulation. Otherwise, the trajectory of the tool may be incorrect (shifted relative to the coordinate system of the workpiece, duplicated approaches/retracts, incorrect starting position, etc.).
