Utilities button of main panel
The utilities menu contains items for running some additional internal tools and external user utilities. You can tune it by clicking the Configure utilities menu item. Some items can be hidden, depending on the Show expert tools option in the system settings.
Button |
Description |
Configure utilities – shows the Utility manager window. |
Addin manager – opens the Addin Manager window. |
Calculator – runs an internal calculator. |
Postprocessors generator – runs the Postprocessors generator - application to generate postprocessor tuning files. |
CLData viewer – starts the CLData viewer – the application which helps to create C# based postprocessors. |
Create interpreter - shows the Create interpreter window. |
System logs - opens the window which contains a list of events that have occurred in the application since launch. |
Machine maker – starts the application to create Machine schemas. |
Scripts IDE - opens the window to write and debug Sprut script files. |
Operations manager - starts the manager that allow to enable/disable external operations, whose parameters are described inside separate xml-files and stfc-containers. |
Create script operation - shows the dialog to create a scriptable operation. |
