Hole capping
Quite often a geometrical model has holes the machining of which has been performed earlier or are required to be machined in a later operation. In this case, when machining the surface that has the hole, it can be ignored. The ignored holes can be of any shape (not always round). The defined size describes the diameter of a disk that can cover the hole.
images/download/attachments/84216374/Img5_4_36.gif
images/download/attachments/84216374/Img5_4_36_2.gif
Definition machining strategy
Defining holes by coordinates
Defining holes by using a geometrical "point" object
Automatic hole recognition
