Corners smoothing
images/download/attachments/84216370/Img5_4_35_1.gif
When there is a sudden change of the tool movement direction, the milling unit performs deceleration before starting the turn, and then accelerates again. This fact can lead to vibrations and high tool and milling machine wear. The problem can be solved if the toolpath has very few or no breaks. For this reason, in the system there is the toolpath smoothing function at the defined radius for machining inner corners of the model.
An example of machining with corner smoothing:
images/download/attachments/84216370/Img5_4_35_2.gif
Definition machining strategy
