Configurations and options
SprutCAM X 16 configurations
Express
The most simple configuration, only single Z level machining.
Available operations: Pocketing, Hole machining, 2D contouring, Flat land, Auxiliary.
Cutting
Contains the operations for the 2D milling and cutting. Designed especially for the 2-axis milling machines or cutters.
Available operations: 2D contouring , Hole machining, Jet cutting 2D, Jet Cutting 4D, Auxiliary.
2.5x Mill
Parts production based on drawings. Drawing can be created with embedded SprutCAM X drawing editor or imported. This configuration does not work with faces.
In combination with "Lathe" option can be used for mill-turn machines programming.
Available operations: 2D contouring, Flat land, Face Milling, Hole machining, Engraving, Pocketing, 2.5D pocketing, 2.5D flat land, 2.5D wall machining, 2.5D contouring, Chamfering, Jet Cutting 2D.
3x Mill Entry
Configuration for parts production using a 3-axis milling machine and 3D model of the part. Best for production parts with simple curved surfaces.
All operations form 2.5x mill: 2D contouring, Flat land, Face Milling, Hole machining, Engraving, Pocketing, 2.5D pocketing, 2.5D flat land, 2.5D wall machining, 2.5D contouring, Chamfering, Jet Cutting 2D.
And: Roughing waterline, Roughing Plane, 3D contour, Finishing waterline, Finishing Plane, FBM.
3x Mill Advanced
Ultimate solution for 3-axis machine programming. Including production of parts with complex curved surfaces, for ex. mold & die.
All operations form 3x mill entry: 2D contouring, Flat land, Face Milling, Hole machining, Engraving, Pocketing, 2.5D pocketing, 2.5D flat land, 2.5D wall machining, 2.5D contouring, Chamfering, Jet Cutting 2D, Roughing waterline, Roughing Plane, 3D contour, Finishing waterline, Finishing Plane, FBM.
And: Morph, Scallop, 3D Helical, Optimized Plane, Complex, 5D surfacing (in 3D mode), Pencil, Corners cleanup.
Rotary
Rotary milling programming for 4-axis milling machine.
All operations form 3x mill advanced: 2D contouring, Flat land, Face Milling, Hole machining, Engraving, Pocketing, 2.5D pocketing, 2.5D flat land, 2.5D wall machining, 2.5D contouring, Chamfering, Jet Cutting 2D, Roughing waterline, Roughing Plane, 3D contour, Finishing waterline, Finishing Plane, FBM, Jet cutting, Morph, Scallop, 3D Helical, Optimized Plane, Complex, 5D surfacing (in 3D mode), Pencil, Corners cleanup.
And: Rotary roughing, Rotary finishing, Rotary Waterline, 4D contour, 4D surface, 4D Morph.
5x Mill
SprutCAM X for milling machines at its full power. Capable of programming 5-axis machines with TCPM.
Plus:
All operations form Rotary: Rotary roughing, Rotary finishing, Rotary Waterline, 4D contour, 4D surface, 4D Morph.
Plus 5-axis toolpaths: 5D surfacing, 5D contouring, 5D by meshes, 5D cutting.
Lathe
Contains the full kit of the lathe operations. Designed for the lathes and turning centers.
WireEDM
Contains the operations for 2-axis, 2-axis with taper and full 4-axis wire EDM cutting. Designed especially for the wire EDM machines.
Options
Turn
Turning operations. Available for all configurations starting from 2.5x mill.
Configurations and machine match table:
Machine |
Configuration |
Lathe Z X |
Turn ZXCY |
Mill-turn X Z C (Y) |
2.5x Mill + Turn ZXCY 3x Mill Entry+ Turn ZXCY 3x Mill Advanced + Turn ZXCY Rotary + Turn ZXCY
5x Mill + TurnXZCY
Mill-turn X Z C Y B |
5x Mill + Turn ZXCYB |
Multichannel machining is a separate option and not included in "Turn" by default.
3+2 (5-axis index) machining
This option is enabling LCS usage and comprehensive approach and retract as well as links handling for multiaxis machines.
This option is included and turned off into all milling configurations starting from 2.5x mill by default. Users can turn it on when needed.
Adaptive SC
SprutCAM X's module for high speed milling. Full reference.
Multichannel
Option enables multichannel machining with user defined synchronization points. Robots are supported. Good for dual channel. Harder to use for 3+ channel machining.
G-code based
Option adds support for G-code based operations: "G-code based", "G-code based lathe".
These operations allows you to perform:
direct control of the machine simulation using G-codes;
check and optimize the NC program;
convert the text of the NC from one controller to another (for machines with identical kinematic scheme);
debug your own interpreter during its creation.
The use of Wire EDM machining is not supported.
Cladding
The optional module of SprutCAM X which includes operations for additive manufacturing. Full Reference.
Disk tool
This group of operations is designed for sawing and machining materials such as wood, stone and similar with a disk tool.
Knife cutting
Special operations for knife cutting 2D and 6D. Full reference.
Teamcenter integration
This integration module is designed to obtain the required in creating NC code data for CNC machines from PLM system to Teamcenter and for transferring the NC code, list of processing operation and a statement of the tool to the PLM-system after tool path calculation.
Robot+
Allows to add feature that make it possible to control 6-axis (articulated) robots when you have only configuration of SprutCAM X for usual machines (milling etc.).
Painting
Painting simulation allows you to see the areas of the parts that will be painted, as well as perform control of the thickness of the future paintwork (depending on the chosen type of painting).
ModuleWorks
This module useful for create tool paths for 3, 4, and 5axis machines, and industrial robots ( last only for SprutCAM X : Robots + 5D MW).
Heat treatment
The following operations are possible
Laser heat treatment;
Gas-plasma heat treatment;
Another kind of heat treatment processes.
