Relief angle
When machining deep vertical walls, it is sometimes needed to restrict tool contact with the already machined part. For this purpose, in the operations that perform machining by layers, it is possible to assign a relief angle. When machining a vertical (or close to vertical) surface, the real stock will increase at machining layer as shown in the picture (below). The relief angle is allowed for all walls that are close to vertical, i.e. not only close for the model being machined, but also the restricting ones.
The relief angle value cannot be negative, nor can it be more than or equal to 90 degrees. Setting the relief angle too high will lead to a large layer of unmachined material at the lower layers.
The relief angle can be assigned on the <Parameters> page.
images/download/attachments/84216270/f_clip0162.png
Lateral angle
Definition machining strategy
