Turning cycle threading
INCT_LatheThreadCuttingCycleFormer - SprutCAM X interface that implements functionality to simplify the formation of the movements of a thread-cutting turning cycle. The object that implements this interface is returned by the INCT_CLData.CreateLatheCycleFormer, INCT_GeomCLData.CreateLatheCycleFormer function when it is executed with the lctThreadCutting parameter.
images/download/attachments/84218648/ThreadCuttingCycle_Outer.png
images/download/attachments/84218648/ThreadCuttingCycle_Inner.png
images/download/attachments/84218648/ThreadCuttingCycle_Params.png
Purpose:
Performing movements in different types of turning cycles for threading, for different racks in general, repeat the same path:
  1. Instrument approach to the starting point or the point of the next run in the retraction plane at the accelerated feed.
  2. Move to the start point of the thread on the work feed.
  3. Tapping to the end point on the work feed.
  4. Return to the retraction plane in the flow with accelerated movement.
  5. If the number of entries (roughing and finishing) are not finished, return to Step 1.
Examples of such cycles, Sinumerik: CYCLE97.
Using the former allows you to set the parameters: the start and end points of the thread, the plane of retracts, the number of hits of the thread, the method of cutting down, the angle of cutting down, etc., to form the tool path. And also add the features necessary for a particular cycle to the path on any formed section, change the type or value of feed, or skip the tool path prepared by the former.
Shaper use:
We recommend creating a new turning cycle generator for each new cycle in the G-code frame, except when the cycle operation is repeated in a new frame. Thus, the interface of the old driver must be freed when creating a new one or shutting down the interpreter.
To form commands for moving an instrument along a cycle path, the following steps must be performed:
  1. Get shaper interface (INCT_CLData.CreateLatheCycleFormer, INCT_GeomCLData.CreateLatheCycleFormer).
  2. Set the indexes of the longitudinal and transverse axes along on which movements will be made (Set_AxisIndexes).
  3. Set the cycle parameters (Set_ThreadOrientation, Set_ThreadDepth, Set_ThreadStep, Set_ThreadStartAngle, Set_StartPoint etc., see the description below).
  4. If changes to the loop path are needed, set a loop event handler (Set_Events).
  5. To form teams of tool path along the cycle path (MakeWorkpath).
Method
Method description
Set_AxisIndexes
The method establishes the indexes of the longitudinal and transverse axes along which movements will be made during the formation of the cycle path.
Input parameters: Value (TNCLCAxisIndexes) - Transverse (integer) - transverse axis index, Longitudinal (integer) - longitudinal axis index.
No output parameters.
Get_AxisIndexes
The function returns the indexes of the longitudinal and transverse axes in which the movements will be made during the formation of the cycle trajectory (TNCLCAxisIndexes).
No input parameters.
Set_Direction
The method sets the direction of the cycle.
Input parameter: Value (TNCThreadCuttingDirection) - cycle direction: drLongitudinal - longitudinal, drTransverse - transverse.
Get_Direction
The function returns the direction of the cycle (TNCThreadCuttingDirection).
The method sets the type of thread orientation.
Input parameter: Value (TNCThreadOrientation see INCT_CLData.AddSinglePassThread) - thread type orientation.
Get_ThreadOrientation
The function returns the thread orientation (TNCThreadOrientation).
Set_ThreadDepth
The method sets the value of the thread depth.
Input parameter: Value (number) - thread depth value.
Get_ThreadDepth
The function returns the value of the thread depth (number).
Set_ThreadStep
The method sets the value of the thread step.
Input parameter: Value (number) - thread step value.
Get_ThreadStep
The function returns the value of the thread step (number).
The method sets the value of the initial angle of the thread.
Input parameter: Value (number) - the value of the initial angle of the thread.
Get_ThreadStartAngle
The function returns the value of the initial angle of the thread (number).
Set_ThreadStartCount
The method sets the value of the thread starts.
Input parameter: Value (integer) - thread count.
Get_ThreadStartCount
The function returns the number of thread hits (integer).
Set_StartPoint
The method sets the coordinates of the starting point of the thread.
Input parameter: Value (TNC2DPoint) - the coordinates of the starting point of the thread.
Get_StartPoint
The function returns the coordinates of the starting point of the thread. (TNC2DPoint).
Set_EndPoint
The method sets the coordinates of the end point of the thread.
Input parameter: Value (TNC2DPoint) - coordinate values of the end point of the thread.
Get_EndPoint
The function returns the coordinates of the end point of the thread (TNC2DPoint).
Set_TaperDist
The method sets a value of taper between the start and end point of the thread.
Input parameter: Value (number) - value of taper between the start and end point of the thread.
Get_TaperDist
The function returns a value of taper between the start and end point of the thread (number).
Set_ChamferLength
Method sets chamfer length to exit the tool at the end of the thread.
Input parameter: Value (number) - chamfer length to exit the tool at the end of the thread.
Get_ChamferLength
The function returns the chamfer length to exit the tool at the end of the thread (number).
Set_ChamferAngle
The method sets the value of the chamfer angle in degrees.
Input parameter: Value (numbar) - value of the chamfer angle in degrees.
Get_ChamferAngle
The function returns the value of the chamfer angle in degrees (number).
Set_RetractionPath
The method sets the level of the retraction plane.
Input parameter: Value (number) - retraction plane level.
Get_RetractionPath
The function returns the specified level of the retraction plane (number).
Set_RunInPath
The method sets the value of the input area.
Input parameter: Value (number) - input area value.
Get_RunInPath
The function returns the value of the input area (number).
Set_RunOutPath
The method sets the value of the output section.
Input parameter: Value (number) -value of the output section.
Get_RunOutPath
The function returns the value of the output section (number).
Set_ThreadAngle
The method sets the value of the angle of the thread profile.
Input parameter: Value (number) - the value of the angle of the thread profile.
Get_ThreadAngle
The function returns the angle value of the thread profile (number).
Set_InclinationAngle
The method sets the value of the angle of one of the walls of the thread profile relative to the vertical.
Input parameter: Value (number) - value.
Get_InclinationAngle
The function returns the angle value of one of the walls of the thread profile relative to the vertical (number).
Set_SequenceType
The method establishes the method of plunging on roughing cuts.
Input parameters: Value (TNCThreadSequenceType) - thread sequence type on roughing cuts.
stRadial - radial;
stFlank - flank;
stModifiedFlank - at an angle;
stAlternateFlank - alternately flank.
Get_SequenceType
The function returns the plunge method on roughing passes. (TNCThreadSequenceType).
Set_PlungeAngle
The method sets the plunge angle for the stModifiedFlank strategy.
Input parameter: Value (number) - plunge angle value in degrees.
Get_PlungeAngle
The function returns the plunging angle for the stModifiedFlank strategy (number).
Set_DepthIsEqual
Sets the method for determining the depth of cut.
Input parameter: Value (boolean) -method of determining the depth of cut. True - constant depth, False - constant cutting area.
Get_DepthIsEqual
The function returns a method for determining the depth of cut (boolean).
Set_IsPassCountDefined
The method sets the method for determining the cut depth.
Inner parameter: Value (boolean) - method of determining the cut depth. True - by the number of passes, False - by initial depth.
Get_IsPassCountDefined
The function returns the method for determining the depth of cut (boolean).
Set_MinCutDepth
The method sets the value of the minimum possible depth of the rough cut.
Input parameter: Value (number) - the value of the minimum possible depth of the rough pass.
Get_MinCutDepth
The function returns the value of the minimum possible depth of the rough cut (number).
Set_FirstCutDepth
The method sets the depth of the first roughing pass.
Input parameter: Value (number) - depth value of the first rough cut.
Get_FirstCutDepth
The function returns the depth of the first rough cut (number).
Set_RoughPassCount
The method sets the number of rough passes.
Input parameter: Value (integer) - number of rough passes.
Get_RoughPassCount
The function returns the number of rough passes (integer).
Set_FinishPassCount
The method sets the number of finishing passes.
Input parameter: Value (integer) - number of finishing passes.
Get_FinishPassCount
The function returns the number of finishing passes (integer).
Set_FinishPassDepth
The method sets the value of the depth of the finishing passes.
Input parameter: Value (number) - the depth valueof the finishing passes.
Get_FinishPassDepth
The function returns the depth value of the finishing passes (number).
Set_Feedrate
The method sets the value of the work feed.
Input parameter: Value (number) - value of the work feed.
Get_Feedrate
The function returns the value of the work feed.
Set_MPM
The method sets the type of working feed.
Input parameter: Value (logical) - type of working feed. True - mm/min, False - rev/min.
Get_MPM
The function returns the type of working feed.
Set_Events
The method assigns events to control the behavior of the loop. When using events, you can add features that are necessary for a particular cycle to the tool path on any formed section: stop, oriented stop, etc., change the type or value of feed, or skip the tool path prepared by the former.
Input parameter: Value (interface) - an object that implements the interfaces INCT_LatheCycleEvents, INCT_LatheThreadCuttingCycleEvents. See the description below.
Get_Events
The function returns an object that implements the events associated with the loop generator (INCT_LatheCycleEvents, INCT_LatheThreadCuttingCycleEvents).
MakeWorkpath
The method forms a cycle path according to specified parameters.
INCT_LatheCycleEvents - is an interface implemented in the interpreter that allows you to control the behavior of the turning cycle. Described in detail in the article Turning cycle threading.
INCT_LatheThreadCuttingCycleEvents - is an interface implemented in the interpreter that allows you to control threading. The interface describes one method-event OnThread, which is executed when performing threading inside the former.
Method
Method Description
Description of use
OnThread
The method will be executed before each threading while forming the cycle path. The implementation of this method allows you to change the thread parameters for the selected iteration.
Input parameters: Orient (TNCThreadOrientation) - thread orientation; LeadType (TNCThreadLeadType) - way to set the thread pitch; Step (number) - thread step value; StartAngle (number) - the initial angular position of the spindle in degrees (used for multiple threads). See INCT_CLData.AddSinglePassThread.
Input and output parameters: Handled (boolean) - a sign of the execution of the movement within the OnThread implementation (True - the movement is completed, False - the movement is not performed).
If, after calling OnThread, the Handled parameter takes the value True, this means that threading was performed inside the implementation of the OnThread method and the loop builder does not add the threading command to the tool movement path.
If, after calling OnThread, the Handled parameter takes the value False, the driver assumes that threading was not performed inside the implementation of the OnThread method and adds a threading command to the tool movement path.
If necessary, replace the parameters of threading. Either the task of the thread change algorithm at different approaches that are not implemented in the former.
OnCalcBaseDepth
The method is executed for IsPassCountDefined = True mode, after the calculation base (first) depth. The implementation of this method allows you to change the base depth.
Input and output parameter: BaseDepth (number) - base depth.
OnCalcCount
The method is executed for IsPassCountDefined = False mode, after calculating the number of passes. Implementation of this method allows to change the value of the number of passes.
Input and output parameter: Count (integer) - number of passes.
OnCalcNextDepth
The method is executed in the calculation of the next depth (if the number of passages greater than or equal to one). The implementation of this method allows you to change the depth value for iteration.
Input parameter: Iteration (integer) - iteration number (passage);
Input and output parameter: Depth (number) - depth at iteration.
OnCalcPoint
The method is executed in the calculation of coordinates for the next tool position displacement. The implementation of this method allows you to change the coordinate value for iteration.
Input and output parameter: APoint (TNC2DPoint) - Tool position coordinates for iteration.
