Tapping cycle, tapping with chip breaking and removing (G84, W5DTap(484))
Tapping cycle performs rapid approach to the <Z return> level, thread tapping with subsequent retraction at work feedrate with reverse spindle rotation.
<G84> tapping cycle includes:
Rapid approach to the hole center at the <Z return> level.
Rapid travel to the <Z safe level>.
Work feedrate motion to the <Z min> level and then <Spindle reverse>. If you select the tapping with chip removing or breaking strategy, the finish depth of the hole will be reached in several iterations.
Work feed travel to the <Z safe> level.
Rapid retract to the <Z return> level.
Restore spindle rotation direction and speed.
The cycle parameters are defined in the <Thread parameters> panel. The <Thread pitch> defines the pitch in millimeters or inches. It depends on the current measurement units. The <Spindle position> is used for the multistart threads and defines the start <Spindle position> in degrees.
<Chip breaking parameters> panel defines the <Step>, <Deceleration> and <LeadOut>. The step can be specified by different ways:
<Distance>. The step is equal to the input value.
<Count>. The value defines the quantity of the tool pecks. The step is calculated as the hole depth divided into the peck count.
<Percent>. The step is specified in the percent of the tool diameter.
If the <Depth degression> is checked then the depth of every following peck is reduced on the defined value, else the step is constant. The step reduction occurs until its value is not less than <Minimal step>. Minimal step is a percentage of the first step value.
Some numerical controls has different cycles for the different socket type. So the socket type can be defined as floating or fixed.
