Approach, retraction, and plunge methods
Use the <Links/Leads> dialog to specify parameters that define tool approach to cutting passes and tool retraction from cutting end point. The actual dialog window is changed according to the current operation.
Approach and retraction of mill operations
Plunge methods of mill operations
Compound approaches and retractions of mill operations
Controlling tool's transition between operations
