4D contouring operation
images/download/thumbnails/84216957/4DCurve.png
Operation based on the 5D contouring operation and perconfigurated for rotary machining and available for 4x and 5x configurations.
Tool orientation set as default "To Rotary axis".
Tool orientation "Through point" and "Through curve", Advanced axes limits control,Side angle,Lead and Lean angles options are blocked.
Safe surface set as "Cylinder".
5D contour and 6D contour operations
5 axis machining
5-axis milling along the isoparametric curves
5-axis milling of the profile on the surface
5-axis milling of the ruled surfaces by the flank of the mill
