Drilling with chip breaking cycle (G73, W5DChipBreaking(473))
Drilling with chip breaking cycle performs tool approach to the hole center at the <Z return level>. When cyclic drilling is performed with tool retraction for chip breaking.
images/download/attachments/84216535/G73.PNG
The cycle consists of:
  • Rapid approach to the hole center at the <Z return> level.
  • Rapid travel to the <Z safe> level.
  • Work feedrate motion to the <Step depth S>.
  • Dwell for the <Delay> at the bottom time.
  • Rapid tool retraction for the <Withdrawal distance (Ld)>.
  • Dwell for the <Dwell at the top> time.
  • Rapid motion to the previous depth level, with a <Deceleration (Dcl)>.
  • Work feedrate to the <Deceleration (Dcl)> with <Step (S)>.
  • Dwell at for the <Dwell at the bottom> time.
  • Repeat previous five iterations until the full hole depth is reached.
  • Rapid tool return to the <Z retract> level.
<Chip breaking parameters> panel defines the <Step>, <Deceleration> and <LeadOut>. The step can be specified by different ways:
  • <Distance>. The step is equal to the input value.
  • <Count>. The value defines the quantity of the tool pecks. The step is calculated as the hole depth divided into the peck count.
  • <Percent>. The step is specified in the percent of the tool diameter.
If the <Depth degression> is checked then the depth of every following peck is reduced on the defined value, else the step is constant. The step reduction occurs until its value is not less than <Minimal step>. Minimal step is a percentage of the first step value.
images/download/attachments/84216535/image2022-4-7_10-42-38.png
images/download/attachments/84216535/image2022-4-7_10-30-53.png
Hole machining operation
