Drilling with chip removing cycle (G83, W5DChipRemoving(483))
Drilling with chip removing cycle performs tool motion to the hole center at the <Z return> level and consequent cyclic drill with tool retraction to the <Z safe> level.
images/download/attachments/84216530/G83.PNG
Cycle consists of:
  • Rapid approach to the hole center at the <Z return> level.
  • Rapid travel to the <Z safe> level.
  • Work feedrate motion to the <Step depth S>.
  • Dwell for the <Delay at the bottom> time.
  • Rapid return to <Z safe> level.
  • Dwell for the <Dwell at the top> time.
  • Rapid motion to the previous depth level, with a <Deceleration (Dcl)>.
  • Work feedrate to the <Deceleration (Dcl)> with <Step (S)>.
  • Dwell at for the <Dwell at the bottom> time.
  • Repeat previous five iterations until the full hole depth is reached.
  • Rapid tool return to the <Z retract> level.
Chip breaking parameters panel defines the step and deceleration. The <Step> can be specified by different ways:
  • <Distance>. The step is equal to the input value.
  • <Count>. The value defines the quantity of the tool pecks. The step is calculated as the hole depth divided into the peck count.
  • <Percent>. The step is specified in the percent of the tool diameter.
If the <Degression> is checked then the depth of every following peck is reduced on the defined value, else the step is constant. The step reduction occurs until its value is not less than <Minimal step>. Minimal step is a percentage of the first step value.
images/download/attachments/84216530/image2022-4-7_10-41-39.png
images/download/attachments/84216530/image2022-4-7_10-30-29.png
Hole machining operation
