Double wall external corner probing parameters
images/download/attachments/95446791/image2022-4-5_22-37-24.png images/download/attachments/95446791/image2022-4-5_22-37-40.png
Double wall external corner probing consist of the following steps:
  1. The tool moves the distance specified in the < Feed distance > and approaches the starting point of the measurement cycle that is the intersection of first touch point of first side and first touch point of second side at a distance specified in <Clearance 1>, <Clearance 2> , respectively, along orthogonal direction of their vectors. Moving at "Approach feed";
  2. The tool approaches a point remote from the first touch point on first side along its < Target vector > at the < C learance 1 > distance (m oving at "Long link feed" ) and approaches first touch point of the first side (moving at "Work feed") and then returns (m oving at "Long link feed" ) to previous position ;
  3. If <First wall measure count> >1 then:
    1. The tool moves to the next touch point on the current side at a distance specified in the <Clearance 1> in the direction of its target vector;
    2. The tool approaches touch point (moving at "Work feed") and then returns (m oving at "Long link feed" ) to previous position;
  4. S teps 3 are repeated as many times as indicated in <First wall measure count>;
  5. The tool returns to the starting point of the cycle. Moving at "Long link feed";
  6. The tool approaches a point remote from the first touch point on second side along its < Target vector > at the < C learance 2 > distance (m oving at "Long link feed" ) approaches first touch point of the second side (moving at "Work feed") and then returns (m oving at "Long link feed" ) to previous position ;
  7. If <Second wall measure count> >1 then:
    1. The tool moves to the next touch point on the current side at a distance specified in the <Clearance 2> in the direction of its target vector;
  8. S teps 7 are repeated as many times as indicated in <Second wall measure count>;
  9. The tool returns to the starting point of the cycle. Moving at "Long link feed";
  10. The tool is lifted up by a distance equal to <Feed distance >.
Parameters:
CLDArray
Type
Description
CmdPrm.Int[-1]
Integer
Probing cycle type: Double wall external corner probing value = 14
CmdPrm.Int[-2]
Integer
CmdPrm.Flt[-50]
Double
Feed distance, distance to start position of cycle
CmdPrm.Flt[-56]
Double
Clearance 1, approach distance to touch poin ts on first side
CmdPrm.Flt[-57]
Double
Clearance 2, approach distance to touch poin ts on second side
CmdPrm.Int[-63]
Integer
First wall measure count, count of touch points on first side
CmdPrm.Int[-64]
Integer
Second wall measure count, count of touch points on second side
CmdPrm.Flt[-65]
Double
Step 1, distance between touch points on first wall
CmdPrm.Flt[-66]
Double
Step 2, distance between touch points on second wall
CmdPrm.Flt[-100]
Double
First touch point on first side value along X-axis
CmdPrm. Flt [-101]
Double
First t ouch point on first side value along Y-axis
CmdPrm. Flt [-102]
Double
First t ouch point on first side value along Z-axis
CmdPrm.Flt[-103]
Double
First target vector on first side value along X-axis
CmdPrm. Flt [-104]
Double
First target vector on first side value along Y-axis
CmdPrm. Flt [-105]
Double
First target vector on first side value along Z-axis
CmdPrm.Flt[-100-((N-1)*6)]
Double
Other touch point on first/second side value along X-axis. N - number of touch point
CmdPrm.Flt[-101-((N-1)*6)]
Double
Other touch point on first/second side value along Y-axis. N - number of touch point
CmdPrm.Flt[-102-((N-1)*6)]
Double
Other touch point on first/second side value along Z-axis. N - number of touch point
CmdPrm.Flt[-103-((N-1)*6)]
Double
Other target vector on first/second side value along X-axis . N - number of touch point
CmdPrm.Flt[-104-((N-1)*6)]
Double
Other target vector on first/second side value along Y-axis . N - number of touch point
CmdPrm.Flt[-105-((N-1)*6)]
Double
Other target vector on first/second side value along Z-axis . N - number of touch point
