Web probing (three points) parameters
images/download/attachments/95446774/image2022-4-5_20-50-6.png
Web probing (three points) consist of the following steps:
  1. The tool moves the distance specified in the < Feed distance > and approaches the starting position of the cycle. Moving at "Approach feed";
  2. The tool approaches a point remote from the left touch point along its <Target vector> at the <Side clearance> distance but elevated at the < Top clearance > value + < Depth > value . Moving at "Long link feed" ;
  3. The tool is lowered by a distance equal to <Top clearance> value + <Depth> value . Moving at "Long link feed" ;
  4. T he tool approaches the left touch point (m oving at "Work feed" ) and then returns (m oving at "Long link feed" ) to previous position;
  5. The tool is lifted up by a distance equal to < Top clearance > value + < Depth > value . Moving at "Long link feed" ;
  6. The tool returns to the starting position;
  7. Steps 2-6 are repeated for the right touch point;
  8. T he tool approaches the middle touch point (m oving at "Work feed" ) and then returns (m oving at "Long link feed" ) to previous position;
  9. The tool is lifted up by a distance equal to <Feed distance >.
Parameters:
CLDArray
Type
Description
CmdPrm.Int[-1]
Integer
Probing cycle type: Web probing (three points) value = 10
CmdPrm.Int[-2]
Integer
CmdPrm.Flt[-50]
Double
Feed distance, distance to start position of cycle
CmdPrm.Flt[-51]
Double
Depth, distance from middle side to center of left and right point
CmdPrm.Flt[-53]
Double
Width, distance from left point to right point
CmdPrm.Flt[-56]
Double
Side clearance, approach distance to right/left touch poin t
CmdPrm.Flt[-57]
Double
Middle clearance, approach distance to middle touch poin t
CmdPrm.Flt[-100]
Double
Left touch point value along X-axis
CmdPrm. Flt [-101]
Double
Left t ouch point value along Y-axis
CmdPrm. Flt [-102]
Double
Left t ouch point value along Z-axis
CmdPrm.Flt[-103]
Double
Left target vector value along X-axis
CmdPrm. Flt [-104]
Double
Left target vector value along Y-axis
CmdPrm. Flt [-105]
Double
Left target vector value along Z-axis
CmdPrm.Flt[-106]
Double
Right touch point value along X-axis
CmdPrm. Flt [-107]
Double
Right t ouch point value along Y-axis
CmdPrm. Flt [-108]
Double
Right t ouch point value along Z-axis
CmdPrm.Flt[-109]
Double
Right target vector value along X-axis
CmdPrm. Flt [-110]
Double
Right target vector value along Y-axis
CmdPrm. Flt [-111]
Double
Right target vector value along Z-axis
CmdPrm.Flt[-112]
Double
Middle touch point value along X-axis
CmdPrm. Flt [-113]
Double
Middle t ouch point value along Y-axis
CmdPrm. Flt [-114]
Double
Middle t ouch point value along Z-axis
CmdPrm.Flt[-115]
Double
Middle target vector value along X-axis
CmdPrm. Flt [-116]
Double
Middle target vector value along Y-axis
CmdPrm. Flt [-117]
Double
Middle target vector value along Z-axis
